Steering wheel off center after RedHead gearbox (2wd)
Old Oct 20, 2017 | 01:25 PM
Deagle12's Avatar
Deagle12
Is it worth it/possible to adjust on my own, or do I need to get an alignment?
Any issue driving like this for a while?
Any ideas why after install redheads people's steering wheels are often off center turned to the right like this? What causes that?
Old Oct 20, 2017 | 01:29 PM
Oldguyfl's Avatar
Oldguyfl
Just adjust the link that comes off your steering box. Simple, the yellow one. 15mm socket required I believe.
Old Oct 20, 2017 | 02:12 PM
Deagle12's Avatar
Deagle12
Oh nice, for some reason I thought that method was not available on 2wd.
Old Oct 20, 2017 | 02:55 PM
Oldguyfl's Avatar
Oldguyfl
Pretty sure, crawl under and take a look and see.
Old Oct 20, 2017 | 03:05 PM
thor363's Avatar
thor363
15mm it is, just did mine. Get the front wheels off the ground though first.
Old Oct 20, 2017 | 03:42 PM
wpnaes's Avatar
wpnaes
From our tech folder.
https://www.ford-trucks.com/forums/7...ml#post6587322
Old Oct 20, 2017 | 06:27 PM
Misky6.0's Avatar
Misky6.0
just make sure the steering gear is centered, before you adjust the wheel.
It's possible, the gear was 100 (or 50%) left (or right) when you install it. Before you adjust the wheel, verify you have the same # of turns left and to the right.. better to only adjust it once!
Old Oct 20, 2017 | 09:09 PM
Deagle12's Avatar
Deagle12
Ok well it looks like it is different for 2wd, at least in my case. There's only an adjusting sleeve at each wheel not in the center
Old Oct 21, 2017 | 10:08 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by Deagle12
Ok well it looks like it is different for 2wd, at least in my case. There's only an adjusting sleeve at each wheel not in the center. ....
The 2wd steering linkage is not like in the diagram.
The 2 adjusting sleeves are at the outer rod ends on each side.
The steering can still be centered, you just have to adjust both sleeves the same amount in the same direction.
The adjusting sleeves are used to adjust toe-in, but when both are turned say 1/8 turn , the toe-in will not be changed, the linkage length will remain the same length.
I need to do the same adjustment on ours except the other direction, just haven't gotten to it.
Not sure which way moves the steering wheel clockwise.
Both of my adjusting sleeves point down, so I'm going to rotate the sleeves 1/8 turn the same direction and see what happens to the wheel.
The 2wd Excursion steering linkage is very similar to this pic.
Old Oct 21, 2017 | 10:20 PM
thor363's Avatar
thor363
Scratch my response.
Metal twister
15
Dec 7, 2016 05:33 PM
JH1975
Aug 13, 2015 10:18 AM
garagegods
13
Jul 21, 2015 08:58 AM
reed1951
Ford Truck Parts for Sale
May 23, 2015 04:34 PM
chris1911
Aug 7, 2013 06:51 PM
