Sponsored by: Real Truck
Rough Idle after Changing 4 spark plugs
Old Oct 18, 2017 | 11:40 PM
Spartan250's Avatar
Spartan250
Hey All I Got a 2004 F250 Lariat 4Dr Crew Cab Long Bed with he 5.4 in it, I did half a tune up on the truck today before day light ran out, I Replaced all the plugs on the Passenger side will do the drivers side tmrw, but when I started it after the plugs were done the idle was a little rough (not stalling out rough) you can feel it has a little shake to it, I've been reading that the pcv may be bad ? I got the truck scanned at auto zone and it was a p071 code and something else, i checked to make sure I didn't break anything ended up finding nothing wrong, I'm kinda lost. Does this sound like a PCV issue ?
Old Oct 19, 2017 | 06:31 AM
projectSHO89's Avatar
projectSHO89
What did you install for spark plugs?
Old Oct 19, 2017 | 06:50 AM
speakerfritz's Avatar
speakerfritz
did you put dielectric grease on the plug cap ???
I would suspect one of the Coil over plugs
Old Oct 19, 2017 | 09:06 AM
Spartan250's Avatar
Spartan250
I used oem motor craft plugs, wouldn't throw a misfire code if the coil was bad
Old Oct 19, 2017 | 09:08 AM
andym's Avatar
andym
Did you check the gaps on the plugs before you put them in?
Old Oct 19, 2017 | 09:11 AM
Spartan250's Avatar
Spartan250
I did use grease on the plugs
Old Oct 19, 2017 | 11:39 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by Spartan250
Hey All I Got a 2004 F250 Lariat 4Dr Crew Cab Long Bed with he 5.4 in it, ... I got the truck scanned at auto zone and it was a p071 code and something else, ...
Was the code P0171?
If the "something else" was P0174 you probably have a large vacuum leak.
Check the PCV vacuum hose where it connects to the throttle body.
You can get a basic code reader at Amazon for $13 - OBD2 Code Reader - MS300.
Old Oct 19, 2017 | 12:03 PM
Spartan250's Avatar
Spartan250
yea its 171 and 174 I did check the gap its at 55
Old Oct 19, 2017 | 02:51 PM
redford's Avatar
redford
FTE Leadership Emeritus
I would finish changing your plugs before I started throwing money at error codes.
Old Oct 19, 2017 | 03:39 PM
projectSHO89
I would fix whatever was knocked loose and is causing the vacuum leak before driving it.
Old Oct 19, 2017 | 11:23 PM
Spartan250's Avatar
Spartan250
Heres an update, Replaced the PCV valve and replaced the Mass Air Flow and everything seems to be ok drove 100 miles today and the Check Engine Light Did not come back on, The Perks of working for a auto parts store is I have parts at my disposal lol I'll finish the other 4 plugs tmrw
Old Oct 20, 2017 | 04:50 AM
Chuck's First Ford's Avatar
Chuck's First Ford
the real question "IS" did you learn "WHAT" caused the problem. ?????????
throwing parts does not equal learning to repair..
my opinion.
4477rick
2004 - 2008 F150
Jun 20, 2016 02:11 PM
KJ Smith
2009 - 2014 F150
Jan 6, 2015 09:07 AM
jkarne
2004 - 2008 F150
Sep 3, 2010 08:35 AM
ErikLydick
May 5, 2010 04:21 PM
WXboy
1983 - 2012 Ranger & B-Series
Mar 20, 2003 01:54 PM
