Sponsored by: Real Truck
2011 F250 No Horn
Old Oct 16, 2017 | 05:26 PM
rusty86cj's Avatar
rusty86cj
2011 F250 No Horn
2011 F250 horn does not work when the button is pressed. I have checked the fuse, it is fine. Horn still chirps when the doors are locked and also when the panic button is pressed also cruise and all other steering wheel controls are fine. I removed the air bag, all connections are clean and secure as well as the contacts at the corners. I am at a loss........anybody else run into this?
Old Oct 16, 2017 | 07:50 PM
The Bone's Avatar
The Bone
The horn has a relay. You can swap another one from a different spot that has the same number to make sure that the relay is bad before buying another one
Old Oct 16, 2017 | 08:23 PM
Just Strokin's Avatar
Just Strokin
The horn relay is in the BCM and it is NOT serviceable. You might have a bad clock spring or bad SCCM. I suspect a bad clock spring.
The horn switch gives the horn relay a ground, so, I would apply a ground to the points along the steering wheel circuit for the horn to see if it will blow.
Old Oct 16, 2017 | 08:27 PM
rusty86cj's Avatar
rusty86cj
I didn't see a horn relay listed in the owners manual in either the passenger kick panel or the underhood box only a 20A fuse in the kick panel, where do I find the relay?
Old Oct 16, 2017 | 08:45 PM
Just Strokin
Rusty, you didn't read what I wrote nor did you check the wiring diagram I posted. The horn relay is located in the BCM and it is NOT serviceable. It is not replaceable. The BCM would have to be replaced to replace the horn relay. I think you have a bad clock spring or SCCM or switch.
Old Oct 16, 2017 | 08:58 PM
rusty86cj's Avatar
rusty86cj
Larry,
Sorry I was typing when you posted, thanks for the diagram. Since the horn is still functional except for the actual horn button I too think it is isolated to something in the general steering wheel area. My only reservation to thinking it is the clock spring was that everything I read indicated that cruise was typically lost when it fails.
Old Oct 16, 2017 | 09:04 PM
Just Strokin
You can have bad spots on the clock spring. In my truck, the steering wheel button to change the radio stations would jump around backwards or forwards multiple stations when steering wheel was in certain positions. They changes the clock spring and it solved the problem.
You can try turning the steering wheel with engine running as you press the horn button. If it blows in certain positions, I would think clock spring. If not change, I would look at the horn switch next nd lastly the SCCM.
Old Oct 17, 2017 | 07:31 AM
The Bone's Avatar
The Bone
Thats interesting Larry. There have been so many changes to these trucks over the year in electrical systems. Some good some not so much. Sure makes it hard to fix or diagnose simple problems and make for cheap fixes. I found out that I have low voltage to my headlight switch because all the voltage goes to a relay instead of running 12 volts to the switch.
Old Nov 9, 2017 | 06:54 AM
rusty86cj's Avatar
rusty86cj
Yesterday I finally had time to swap out the clock spring, horn is functional again, problem solved.
Just wanted to update the thread in case somebody else may have the same problem.
Thanks for the help!
Old May 29, 2021 | 01:40 PM
Marciniohall's Avatar
Marciniohall
I just bought the 2010 f250 superduty, where is the location of the clock spring and horn switch? Thanks!
Old May 29, 2021 | 10:25 PM
Djosbun's Avatar
Djosbun
Clock spring is behind the airbag inside of the steering wheel.
-- Dave
stbernard
Jan 13, 2017 04:13 PM
Old Time RV'er
May 17, 2016 12:03 PM
buddy26
Modular V10 (6.8l)
Aug 21, 2014 11:05 PM
stanfil82
Apr 30, 2014 02:02 PM
83250XL
Nov 27, 2005 11:40 PM
