Regeneration Mystery
Old Sep 28, 2017 | 08:33 PM
IdahoPoes's Avatar
IdahoPoes
I have a 2016 Ford F-550 with the 6.7L engine. It is the chassis my RV is built on. I keep hearing about regeneration and how often it happens. How do I know it is happening? I have no messages or warning lights going off.
Thanks,
Marshall Poe
mspoe@att.net
Old Sep 29, 2017 | 02:57 PM
swarf_rat's Avatar
swarf_rat
You will see a message, VERY briefly, on the console. It's only there for about 3 seconds and easy to miss. The easiest way to tell is the fuel mileage will drop to about 1/2 for about 20 minutes.
Many owners have had the DPF ghost screen enabled on the console, takes about 10 minutes for a tech to do it, you can do it yourself if you are tech savy. There are many threads about this, search for DPF screen or filter screen. With that enabled you can scroll up to it on the console and see the % full. When it hits 100% you will get a regen within a minute or two. The message that it is actually happening still only comes up for about 3 seconds.
Old Sep 29, 2017 | 04:40 PM
dirthawg's Avatar
dirthawg
Also keep an eye on the boost gauge. The turbo will spool faster under light throttle when the truck is in a regen.
Old Sep 29, 2017 | 04:47 PM
69cj's Avatar
69cj
Egt's 3 an4 will also go from the normal 600 to 700 degrees range up into the 1200's. I follow the egt's with the old ScanGauge that I used on my 6.0.
bigreentruck
Jul 24, 2025 05:07 AM
1HOT-FX2
2004 - 2008 F150
22
Aug 12, 2013 07:28 PM
TJK1
Jan 21, 2012 06:39 AM
cobramustangboy
Electrical Systems/Wiring
Jan 8, 2007 09:09 PM
