76 highboy 390 swap torque converter
Old Sep 17, 2017 | 08:48 AM
fromme87's Avatar
fromme87
I just bought a 390 to swap into my 1976 f250 4x4 as my current 360 is pretty tired and started with some noises. This swap should result in a lot more power as it is fresh and a small cam resulting in what the PO though was about 350 hp. While performing the swap, I might as well get a new torque converter in there as well. Most of the truck is factory so I assume the 4.10 or 4.11 gears and I am running 33 inch tires although may go to 35 sometime. The lowest stall speed torque converter I can find is 2000, will that be too high for this heavy truck? Should I go factory and what is factory?
Old Sep 17, 2017 | 11:08 AM
smle's Avatar
smle
I think that a RV/Towing converter would be the better choice, unless your planning on doing some competition with it.
Old Sep 18, 2017 | 05:17 PM
fromme87's Avatar
fromme87
Thanks. I assume that will put the power to the ground quicker and with less heat? Will that be too much at a stop light?
Old Sep 18, 2017 | 06:33 PM
smle's Avatar
smle
The RV/Towing converter is not that much different from stock. The vanes in the converter are set for better power transfer. It should act a lot like a stock converter. If your worried about heat, add a trans cooler, it won't hurt. They are not that expensive and fairly easy to install.
At the stop light you probably won't notice any difference.
Never assume what your gear ratio is. Triple check it visually.
Old Sep 18, 2017 | 09:12 PM
fromme87's Avatar
fromme87
I think they only put that gear ratio in from the factory for the f 250 4x4 auto. Any brand recommendations for a torque converter?
Old Sep 18, 2017 | 09:52 PM
fromme87's Avatar
fromme87
Old Sep 19, 2017 | 10:36 AM
smle's Avatar
smle
No real recommendations. Just go with a company you trust and fits into your budget.
Suzuki357
Modular V10 (6.8l)
Feb 6, 2018 07:28 AM
jdap
Apr 23, 2010 07:13 AM
jdap
Apr 23, 2010 06:58 AM
kts_fordman1
Nov 15, 2002 05:01 AM
Sunny_in_hollister
Nov 14, 2002 08:59 AM
