Sponsored by: Real Truck
What must I do before first engine start?
Old Aug 14, 2017 | 12:12 PM
F100trauma's Avatar
F100trauma
Hi guys, so my 1977 f100 6.0 powerstroke project is on in last stages before I turn the key and hope for the best, this engine has not been started in about three years, but before I do that I would like to hear from you all, on what I should do to the engine before I attempt to started, I already went ahead and change both fuel filters to oem ones, and have a brand new oil filter and cap ready to go, I will also do a oil change but I have no idea what brand or viscosity to use, I hear that 15w-40 is a good alternative for colorado springs, also when it comes to antifreeze I have no clue which one to use, during the first run I will just used destilled water since I'm going to flush the system, so I will appreciated if I can get some input before I turn the key, I want to make sure that everything goes smooth.
Old Aug 14, 2017 | 12:20 PM
Chuck's First Ford's Avatar
Chuck's First Ford
first question..
is engine a fresh rebuilt..
or used and just sitting.. any prep before storage of engine.
Old Aug 14, 2017 | 12:36 PM
F100trauma's Avatar
F100trauma
Originally Posted by Chuck's First Ford
first question..
it was the rolling chasi out of a 2005 f350 and no it was not rebuilt, the engine had about 65,000 miles before the donor truck got total on a accident, rolled on its side to be exact, I been working on adding my 1977 f100 body on the chasi for the last three years, and I did not do anything to the engine besides just work on adding the older body to it, so it has been without starting in my garage for about three years.
Old Aug 14, 2017 | 04:04 PM
speakerfritz's Avatar
speakerfritz
so the engine was not "fogged" before going dormit????
were the coolant passages sealed up and there was coolant in the engine?
I think I saw a gadget that pressurizes the oil system using a special oil filter cap that gets attached to a hose and tank..id look into that. engine probally went dry while it was on its side. can you turn it by hand?
injectors will probally be stuck...I would add some "stucksion" additive in the engine bay fuel filter.
cycle on and off proceedure to get air out of the system
go to get all the air out of the fuel system.
Old Aug 14, 2017 | 04:46 PM
F100trauma's Avatar
F100trauma
Well no I did not fogged the engine, I did turn the engine using a braker bar a couple months ago and it was easy to turn it, I drained the coolant about a year and a half ago, i did cover the hoses and everything else that still had oil in it, and I will use some of that stucksion in the fuel filter if that is a good idea.
Old Aug 14, 2017 | 06:19 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
"Stiction" additive goes in the oil..... a fuel additive won't do anything for injector stiction on a 6.0, it's a problem with the oil spool valve.
Aaron-71
25
Jan 24, 2018 10:11 PM
aikenmj
1997 - 2003 F150
Oct 18, 2012 01:06 PM
slddnmatt
6.4L Power Stroke Diesel
Mar 18, 2010 09:04 AM
2-16Rangers
Oct 1, 2009 10:31 AM
forddytube
Oil & Lubrication
21
Jul 12, 2004 09:09 PM
