6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Issues with a rollover engine???
Old Mar 18, 2010 | 02:10 AM
slddnmatt's Avatar
slddnmatt
hey all i could use some help. I might try and pick up a friends 2008 F350 that his wife put over on its side at a local auction. engine compartment wasn't damaged at all but for the engine techs, would there be any concerns i should be worried about with the diesel being on its side for an hour or so when it got wrecked? i cant think of anything that would be damaged, with oil being in sloshed around, but then again i dont know alot about the turboed diesels. thanks for any input
matt
Old Mar 18, 2010 | 07:34 AM
senix's Avatar
senix
Well I wounld be checking for oil/coolant mixing. Since you know the people did she shut it down right away? Concern would be no oil flow.
So if all sounds good then maybe get it, dump the oil and start fresh. Just my thoughts.
Old Mar 18, 2010 | 08:24 AM
Tom's Avatar
Tom
Hrmm...
The inertia fuel shutoff switch should have killed the engine when the accident happened. Only way coolant could mix with oil would be if the head gasket were compromised. The cooling system is sealed, therefore regardless of which angle the engine is sitting at contamination shouldn't be possible.
The biggest things I'd watch for would be hidden damage in the engine compartment and possible fuel contamination. If any of the fuel lines got ripped open in the crash you could have contaminants in a VERY expensive fuel system.
Other than that I couldn't think of much that would be damaged by laying on it's side. Whatever you do make sure you check the fluids before starting!
Old Mar 18, 2010 | 09:04 AM
ruschejj's Avatar
ruschejj
Is there any way for engine oil to leak into the air filter/intake? I know it's no lawnmower but oil comes out everywhere on small engines when they are tipped.
Don't rip me if this is stupid. Just trying to cover everything I can think of.
terrymargate
6.7L Power Stroke Diesel
56
Jul 24, 2016 07:45 AM
erwatt
Modular V10 (6.8l)
Aug 28, 2014 08:53 PM
Sparky83
Aftermarket Products
Sep 30, 2009 03:55 PM
speedracer1000
Aug 19, 2009 11:34 PM
Mreddd
3.0L V6
Jun 16, 2009 05:42 PM
