LOST! and getting ready to drive truck into a tree
Old Jun 13, 2017 | 03:29 PM
Mcrncic's Avatar
Mcrncic
I am at a complete loss.
I stopped by a steaknshake about a week ago and turned truck off to talk to nice lady behind the speaker. Went to start up and a horrendous noise kind of grinding but not really. thought maybe starter even tho i just replaced a couple months prior. i roll truck back into a spot and forget about yellow starter wire, have truck towed home. (luckily close to house)
get to house and remember starter wire and try and it cranks like nothing is wrong. Still making horrendous noise with key but starts right up with yellow wire with blue tracer. I take the truck around the block and it is veryyyy sluggish to get going. once going over 10 has normal throttle response. once i hit about 45-50 it makes a different noise then normal, not a bad sound but like something isn't right and doesn't seem to want to shift into overdrive. The other thing i have noticed is the trans temp gauge seems to low. and doesn't move.
Now that i am typing i remember the next day going for another test run the throttle jerked a couple times at a steady idle.
Truck is stock except
-Full EGR delete from NCB diesel
- NCB diesel coolant filter system
I am lost and this is my main work truck. any help would be much appreciated!
Old Jun 13, 2017 | 06:07 PM
Rusty Axlerod's Avatar
Rusty Axlerod
First thing I would check is the starter mount bolts, all present and tight. Starter wiring tight. I'm not sure what the other issues have in common except they could be electrical.
The tree thing sounds like a bad idea to me, more stuff to fix after ya get it running right again.
Old Jun 13, 2017 | 09:42 PM
87crewdually's Avatar
87crewdually
Have you checked battery voltages and terminal condition along with output voltage from the alternator?
Hold off on the tree idea.
Old Jun 13, 2017 | 09:46 PM
TooManyToys.'s Avatar
TooManyToys.
I've thought about a tree ...... bridge abutment ....... ocean........
Old Jun 13, 2017 | 11:14 PM
WatsonR's Avatar
WatsonR
You didn't mention... shooting the darn thing!
Old Jun 14, 2017 | 12:24 AM
Mike189677's Avatar
Mike189677
Don't forget fire. But this looks pretty fun 42lbs may have been a little much.
Old Jun 14, 2017 | 06:32 AM
TooManyToys.
I'm not that inventive.
Old Jun 14, 2017 | 08:37 AM
Benchwrench's Avatar
Benchwrench
OR... you can fly it into a building and blame it on a foreigner. Then have insurance cover the loss.
Old Jun 14, 2017 | 10:02 AM
DarkStarMedia's Avatar
DarkStarMedia
Where abouts are you? there may be a local who can help.
My guess is an electrical issue. check the various harnesses fro chafing.
Richard
Old Jun 14, 2017 | 10:08 AM
TooManyToys.
If he didn't wander off after our wandering "helps", putting your location in your info can get someone's attention if they can help locally.
Old Jun 15, 2017 | 01:06 PM
High_HP's Avatar
High_HP
I had a very similar issue on a car at the 100K mile mark. Turned out to be a bad battery cable even though it looked as good as new. Turned out the cable was corroded in the center under the jacketing, only found that out after I cut it in half. Just an idea.
Old Jun 15, 2017 | 04:31 PM
Mcrncic's Avatar
Mcrncic
I am located in Raleigh, NC. I have not had a chance to even look at it. thankfully i have a box truck i can drive to my jobs.
I thought about the fire idea and could probably pull it off. wood shavings from my planer and a hot engine!
Old Jun 15, 2017 | 04:32 PM
Mcrncic's Avatar
Mcrncic
Also there is a local place about 30 mins away that does diesel and offload but i am swamped with jobs and can't get it up there for a couple weeks
F-250 restorer
20
Jul 4, 2017 04:16 PM
JoeVB
13
Jul 25, 2006 04:06 PM
ScKid
1997 - 2003 F150
Jul 24, 2005 09:07 PM
dgalloway
Feb 24, 2005 06:46 PM
whathappened
Bronco II
15
Dec 22, 2004 04:46 PM
