T45 to 5.0
Old Jun 3, 2017 | 05:00 PM
Kolby Haynes's Avatar
Kolby Haynes
T45 to 5.0
I drive a 91 f150 and the current trans is about to give out. My uncle thankfully has a t45 out of a 1998 mustang GT he's not going to use. The problem is I've read some things that say they don't have an adapter plate that'll fit and some saying they do make one. Any info will help
Old Jun 3, 2017 | 05:08 PM
Mudsport96's Avatar
Mudsport96
That's a whole bunch of work to put that trans in a truck. If you have a manual just find another m5od its will be world's easier.
Old Jun 3, 2017 | 06:10 PM
Kolby Haynes
i mean easy would be nice but I'm getting this t45 for FREE. Not going to buy a tranny if I don't have to
Old Jun 3, 2017 | 06:48 PM
Mudsport96's Avatar
Mudsport96
Do you have an auto or five speed now?
Old Jun 3, 2017 | 06:51 PM
Conanski's Avatar
Conanski
Kolby.. you're not seeing the big picture. First of all you need an adapter plate to mate the trans to the engine.. $$$, then a different trans cross member.. you might get lucky here it's a pretty simply part so who knows. But that is it for the easy stuff. You will definitely need a custom shift linkage because the car shifter is on the tailshaft while the truck shifter is in the body of the trans near the belhousing. And it's a near certainty you will need a custom driveshaft. Clutch hookup could be straight forward but even a slight difference in the fluid line fitting might require a custom part there too. Bottom line is there is no way you're putting that trans in there cheaper or quicker than another M5OD.
Old Jun 3, 2017 | 06:58 PM
85e150's Avatar
85e150
The 1998 Mustang was a 4.6 motor. You are working with a 5.0/302 motor. Bell patterns are different and this is an integral bell trans. Adapter? Would require a machined front plate and a new bell as well. I can't find a plate but I found all this looking:
TREMEC T-45 Transmission -Modern Driveline
Rebuilt T-45 Transmissions in Atlanta Georgia
Posts 10 & 11:
T-45 to 302. Technical discussion within - Ford Mustang Forums : Corral.net Mustang Forum
Serving suggestion: Sell that T45 to a Mustang owner and repair or replace your current trans, or go with a different Tremec, ZF or other fine brand of transmission.
Old Jun 3, 2017 | 06:59 PM
'89F2urd's Avatar
'89F2urd
It'll cost way more than a Trans swap from this Era truck for the reasons above.
thompsj0784
Aug 18, 2015 04:30 PM
94flaresideon20s
Apr 8, 2013 10:14 PM
headautomatica8
15
May 27, 2012 02:21 PM
falcon5spd
Dec 24, 2006 11:35 AM
FORDWRENCHHEAD
Jan 7, 2003 06:17 PM
