The bottom of the motor
Old May 19, 2017 | 09:59 PM
jonAknight's Avatar
jonAknight
Question The bottom of the motor
Hi I was wondering, because Im a beginner in auto repair, so is this bad in a 4.2L
Drain Plug
I don't know why their's extra threads on the bolt.
I don't wanna screw it all the way back in.
Being a beginner I'm not sure what to do
I need some advice on this please
Old May 20, 2017 | 05:01 PM
85e150's Avatar
85e150
Welcome to FTE!
It looks like your drain plug has a helicoil insert repair. Scroll through this to see how that works. This is an engine case, but it works the same on any thick casting with threads:
Installing a time-sert sump plug repair / thread insert ? TGR: Team Ghetto Racing
Was the plug oil-tight?
Old Aug 28, 2017 | 08:41 PM
1saxman's Avatar
1saxman
That's too bad. You may end up putting an oil pan on it. I am so glad that the truck has plenty of ground clearance so I can change oil myself. It may be possible to tap it to a larger size and use a different screw and hi-temp silicone washer. If you tap it you'll have to flush out the oil pan before putting in the new oil. You can use used oil for the flush.
lwclark
Apr 3, 2012 07:06 AM
Spktyr
18
Mar 16, 2012 06:28 AM
fordguy300
Aug 5, 2008 08:44 AM
whiteyfordzx5
May 29, 2007 12:25 PM
cajunbronco
May 22, 2002 05:29 AM
