Oil drain plug
Old Mar 18, 2002 | 11:19 PM
cajunbronco's Avatar
cajunbronco
Oil drain plug
I've got an oil pan drain hole thats stripped out beyond repair.Tried to screw in a double oversized plug and the thread insert inside cracked.I'm thinking about trying to weld on a nut or fitting on the outside of the pan that I can screw another plug into.Does anyone make a weld in type drain bung?I know I've senn them for 02 sensors.Replacing the pan is a major pita.
Thanks,Billy
Old Mar 18, 2002 | 11:48 PM
PAUL_2's Avatar
PAUL_2
Oil drain plug
Billy , I know its a pain to replace the pan , But trying to rig up a shortcut on an oil pan drain nut is asking for trouble . If it lets go your engine wont be far behind .
Old Mar 22, 2002 | 11:56 PM
Wilber15's Avatar
Wilber15
Oil drain plug
Can't you use a tap and die set? Retap out the hole and inset a larger bolt. or is there something illegal in that?? hahaha
Old May 21, 2002 | 09:57 AM
tranthac1's Avatar
tranthac1
Oil drain plug
I had the same problem. If you haven't fixed it yet, get an oversized drain plug from any auto parts store and use a metal washer and a rubber washer (with a tight fit on the bolt) and don't over tighten but tight enough to seal the plug. And it is reusable but change the rubber washer when changing the oil.
Old May 21, 2002 | 04:03 PM
94van's Avatar
94van
Oil drain plug
cajunbronco said, "Tried to screw in a double oversized plug and the thread insert inside cracked".
[hr]
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
Old May 21, 2002 | 08:31 PM
MustangGT221's Avatar
MustangGT221
Oil drain plug
Old May 22, 2002 | 05:29 AM
jarrod316's Avatar
jarrod316
Oil drain plug
i wouldn't try welding to an oil pan on a vehicle even if the oil is drained. there's still oil in there. it will catch on fire from the heat. i've had oil catch fire on a hot exhaust manifold before. heat from welding would set it on fire to. i know its a PITA to remove the oil pan, but if you replace it with a new oil pan you'll never have to do it again. at least not to that truck anyway.
