The bottom of the motor
Hi I was wondering, because Im a beginner in auto repair, so is this bad in a 4.2L
Drain Plug
I don't know why their's extra threads on the bolt.
I don't wanna screw it all the way back in.
Being a beginner I'm not sure what to do
I need some advice on this please
Drain Plug
Welcome to FTE!
It looks like your drain plug has a helicoil insert repair. Scroll through this to see how that works. This is an engine case, but it works the same on any thick casting with threads:
Installing a time-sert sump plug repair / thread insert ? TGR: Team Ghetto Racing
Was the plug oil-tight?
That's too bad. You may end up putting an oil pan on it. I am so glad that the truck has plenty of ground clearance so I can change oil myself. It may be possible to tap it to a larger size and use a different screw and hi-temp silicone washer. If you tap it you'll have to flush out the oil pan before putting in the new oil. You can use used oil for the flush.
whiteyfordzx5
05-29-2007 12:25 PM
