Removing Jail bars.....
Old Feb 27, 2017 | 09:17 PM
pns112500's Avatar
pns112500
I doubt I'm going to be able to remove the bars without snapping the bolts. Are the bolts replaceable? I haven't taken them off yet, they've been soaking in PB Blaster.
Old Feb 28, 2017 | 10:52 AM
GB SISSON's Avatar
GB SISSON
I have broken my share. They are available (sort of). I think it was C and G ford parts but others offer them. They have a square 'head' that is too large to fit into the back of the bar. I have put them in the vise and ground the flats until they fit. Better yet I bought some 1/8 x 1/2 flat stock and some 10-24 machine screws and welded the screws into a row of holes and them chopped them off. I make them about an inch long but the stud needs to be close to one end. Then there are the 3 middle ones that are wider. I think I used fender washers and ground a couple flats onto them. Hope this helps. Be aware the reproduction sets of jailbars don't fit very well. They don't follow the curve at the top of the grille panel.
Old Feb 28, 2017 | 05:03 PM
46fordtruck's Avatar
46fordtruck
It's inevitable, you'll snap some. Like GB said, you can make some up, or buy some universal trim clips. You'll see what they look like once you remove the bars, they aren't anything fancy or specific to these trucks.
Old Feb 28, 2017 | 08:03 PM
pns112500's Avatar
pns112500
10-4. Thanks.
Old Mar 1, 2017 | 09:54 AM
GB SISSON's Avatar
GB SISSON
Actually it was 10-24....
Old Mar 1, 2017 | 10:09 AM
tacomacream's Avatar
tacomacream
The originals are 10-32. Try to save them if you are not in a hurry. Heat is your friend, but not to the molten state.
mattimeo
Oct 30, 2007 07:39 AM
mdbayler
1983 - 2012 Ranger & B-Series
Sep 9, 2005 11:26 AM
jhromy
Mar 8, 2004 02:56 PM
FTE Ken
1978 - 1996 Big Bronco
Sep 25, 2001 09:45 PM
