Hole in the center of the roof?
Old Jan 31, 2017 | 11:31 AM
yozsi's Avatar
yozsi
Just realized my 64 f100 has a hole dead center of the roof, about 5/8th diameter with a little round metal pop in plug in it. Looks to me a stamped hole and there also is a hole in the factory headliner that matches up. Only problem is it started to leak water and ruined the headliner. Anyone know what this was for? Spotlight? Antenna?
Old Jan 31, 2017 | 12:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Hole in roof either for spotlight or siren.
Old Jan 31, 2017 | 03:39 PM
jowilker's Avatar
jowilker
Most likely from antenna. Siren or spotlight would have had more holes than one.
John
Old Feb 1, 2017 | 03:35 PM
dank4120's Avatar
dank4120
I was thinking antenna hole too, for commercial or private CB radio. Many believe the roof centre is still the best spot for antenna mounting, compared to a fender mount.
Old Feb 3, 2017 | 04:27 PM
TxStang2010's Avatar
TxStang2010
I had a center hole in mine as well , welded it up while doing body work . My truck was originally a County owned vehicle which had a yellow spinning caution light on the roof . It was exactly center in the roof and a wire ran down to the ignition switch with a inline fuse .
Old Feb 5, 2017 | 09:35 AM
hello113's Avatar
hello113
my truck had a part of a antenna in the center it wasn't leaking until I power washed it
all the years of hocky puc came off and it started leaking... so the hole has a welded plate in it I could see it could of been a big problem with a head liner in it
Old Feb 6, 2017 | 09:05 AM
svolpone's Avatar
svolpone
yeah, cb radio was my first guess. I had the same thing on my old 63.
Old Feb 13, 2017 | 05:18 PM
ulfie's Avatar
ulfie
This is what I found under the roof of my 66 f250!
I started a thread to see if any others had the same.
https://www.ford-trucks.com/forums/1...-question.html
Ulfie
jd58980
Jan 6, 2011 08:25 PM
flipklos
May 6, 2009 10:03 PM
Fuzzy
Feb 26, 2006 06:59 AM
jasonschwenk
Feb 21, 2006 06:53 AM
The Fish
1978 - 1996 Big Bronco
17
Sep 10, 2004 01:09 AM
