Hole in roof.
Old Feb 24, 2006 | 10:13 PM
Fuzzy's Avatar
Fuzzy
Hole in roof.
My son just showed me a hole in the roof of my truck.Its about >.< that big.Scared of what I might see when I take the headliner out.Has to be rusting from the inside out.
Old Feb 24, 2006 | 10:39 PM
53fatfndr's Avatar
53fatfndr
Tell your son to stop looking at things so close, lol I'll bet your right, but I have a feeling the metal in the surrounding area is just as bad off.
Old Feb 24, 2006 | 11:17 PM
theGman's Avatar
theGman
Sun roof??
Old Feb 24, 2006 | 11:35 PM
huronfarmer's Avatar
huronfarmer
haha...thats exactly what i was thinking when i clicked this thread....time to get a roof cut out of a newer car from a junk yard and slap a sunroof in there.....i almost did that with mine because mine seemed to be like a mountain landscape with all the ups and downs, but i just ended up beatin, bondo-in, and blocking it half ways straight again......
take the headliner out, and see what happens....just make sure to cross your fingers, and hope that the neighbor drilled a really tiny hole in the top of your roof...haha
Old Feb 25, 2006 | 12:38 AM
Crazydan's Avatar
Crazydan
Hope its better then the Haha that huronfarmer wishes on you.
Old Feb 25, 2006 | 06:36 AM
e william's Avatar
e william
Sounds like a good excuse to tell the wife your gonna HAVE TO do a chop top because of the dammage. You would HAVE TO piece the top sections together anyway...right?
If that doesnt work out think ROADSTER !!!
just one small hurdle of many to come, take it with a grin.
good luck, Ed
Old Feb 25, 2006 | 08:09 AM
xfordman's Avatar
xfordman
__________________________________
Fuzzy....where's the hole? Is the headliner wet? Check under the floor mat. I've seen wet floors that were traced down to a pin hole in the seam sealer over the door. The water will run down inside the A-post like it's coming out of a garden hose. That foam under the carpet is not a pad, it's a sponge. Some joints have expandable foam in them that will stop the water even if there is a pinhole. Maybe you got lucky!
Old Feb 25, 2006 | 10:20 AM
Jet Jock's Avatar
Jet Jock
Fuzzy
As long as the area is isolated you can cut, and weld a patch panel in place. The big item is do not over heat the area as the roof panel will warp. As deep as I have been in mine, just last weekend (after paint and interior) we cut out the cowl vent and welded the vent closed. Now I have a very pretty primer gray area on the cowl. BUT IT DON'T LEAK ANYMORE
Old Feb 25, 2006 | 12:58 PM
51ford fan's Avatar
51ford fan
Fuzzy, post some pictures when you get the headliner out so we can see what you are talking about.
Old Feb 25, 2006 | 04:15 PM
Fuzzy's Avatar
Fuzzy
I took down the headliner.Absolutly no rust.Maybe the neighbor did drill a hole.The paint is dead on the roof.I guess the hole was their when it was painted and the paint filled it in.Guess the roof is pretty thin there.
Old Feb 26, 2006 | 06:59 AM
Walston's Avatar
Walston
Maybe a dab of silicone will fix you up, at least for a while.
SuperDuty93
34
Jun 21, 2016 07:51 AM
fordparts429
Jul 14, 2011 05:33 PM
rastiss
Sep 14, 2010 11:09 AM
jonjon2269
Aftermarket Products
Mar 28, 2009 04:51 PM
J2Davis
Feb 18, 2009 10:26 PM
