Sponsored by: Real Truck
2v v10 engine and wiring variations
Old Jan 24, 2017 | 02:15 PM
travis?'s Avatar
travis?
Hey Everybody, i am hoping somebody here will be able to answer a few things for me.
I have a 2005 2v v10 out of an excursion that i am planning on putting in a classic ford.
I have the engine wiring harness, but not the computer or the fuse boxes or other wiring. i plan on running a manual transmission so that means i will need at least the computer from a manual f250/350
so my questions are
1. Are the wiring harnesses different between any of the years between 99-04?
2. Are there any differences between the actual engines themselves, like sensor placement, extra or missing sensors.(not internal engine parts)
3. I have read a little bit, and some people mention immobilizers, do all years between 99-04 come with an immobilizer?
I will ad more when I can think of them lol
thanks in advance.
Old Jan 24, 2017 | 07:40 PM
Sam I Am's Avatar
Sam I Am
I believe that all Excursions had PATS "chip keys" if that is what you mean by immobilizer. None of the 2V V10 trucks did.
If I were you I would be looking for 2V truck harness parts either from a manual transmission truck or contact someone like 5Star to see if you can get the auto trans part written out of the tune.
Old Jan 25, 2017 | 09:52 AM
99f350sd's Avatar
99f350sd
I would go with 2000 or newer the early 99s had differences you don't want to bother with.
Old Jan 25, 2017 | 02:11 PM
wallew's Avatar
wallew
MY 05 EX does have a chip key - I'm pretty sure that without that key, the truck would have to be towed.
My understanding is that all the Excursions came this way.
Can't answer any of the other questions. I too am considering a 2v V10 and putting it into one of the larger sedan made during this period.
Just an engine swap. Unless I need to swap in an auto tranny from either an EX or other Ford truck to make it work correctly.
Good luck on your journey. I've subscribed to see what becomes of this.
thanks
Old Jan 26, 2017 | 09:21 AM
travis?'s Avatar
travis?
PATS yes that what I was thinking of.
It's good to know the trucks don't have that, as I did plan on getting a truck harness.
Old Jan 26, 2017 | 09:23 AM
travis?'s Avatar
travis?
Thanks for this info, good timing too as I had a 99 harness found. But I'll keep looking I am months away from actually needing it anyways lol
Old Jan 26, 2017 | 09:24 AM
travis?'s Avatar
travis?
thanks
Thanks and good luck with your prooject.
I have always wanted to put a v10 in a crown vic haha
Old Jan 26, 2017 | 09:56 AM
MisterCMK's Avatar
MisterCMK
Pats can be turned off in a tune
Old Jan 26, 2017 | 11:39 AM
redford's Avatar
redford
FTE Leadership Emeritus
I know it can be done. A few years back I talked with a guy at a car show. He built an F4 ramp truck for his Model A Roadster Hot Rod that had a 2V V-10.
b6fischer
Oct 24, 2018 07:47 AM
ste40
Sep 21, 2011 05:03 AM
cogden
WTB - Parts & other
May 5, 2010 01:25 AM
Tusc684
Modular V10 (6.8l)
May 12, 2007 12:44 PM
MattMerkl
Modular V10 (6.8l)
16
Dec 15, 2006 07:41 PM
