Sponsored by: Real Truck
Speedometer needle "Jumps"
Old Jan 23, 2017 | 11:03 PM
V12guy's Avatar
V12guy
2001 F250 SD, V10, Auto, 155K miles
While driving home from work I noticed the needle jump from around 55 to 70 on the display, then settle back in at 55 ish. First I just caught it out of the corner of my eye, but watched more closely, and it did it again as I drove.
The tow/haul override button on the shifter was blinking also, (as if it was "Mad" about something)
THEN I noticed that the jump of the Speedometer needle was linked to when I changed from High to Low on the headlights, and vise-versa
I was NOT in cruise mode
The voltmeter did not EVER waver. (I thought that the increased current might be causing a temporary problem of sorts)
Thoughts on where to start looking?
Old Jan 23, 2017 | 11:24 PM
DarkStarMedia's Avatar
DarkStarMedia
Given that it's your speedo and the tranny, 10 to 1 says it's the sensor in the rear diff. pull it and clean off any fuzz that might be on it.
If that doesn't help, replace it.
Richard
EDT: after re-reading and seeing about the headlights I would pull the cluster and headlight switch and check the connections too.
Old Jan 24, 2017 | 11:25 AM
cra_fizzer's Avatar
cra_fizzer
Good chance it's the servo in the dash. Had the same thing in my Class A.
Old Jan 24, 2017 | 12:05 PM
DarkStarMedia
If it was just the servo his tranny wouldn't have issues....
Richard
Old Jan 24, 2017 | 09:41 PM
V12guy's Avatar
V12guy
So you are thinking that there might be a bad/loose connection at/with the light switch?
I will check that out. Thanks
Old Jan 24, 2017 | 10:37 PM
DarkStarMedia
Yes... or a bad ground. If it's like the earlier trucks the signal from the rear diff goes to the ABS module and then to the cluster and transmission module (going by memory here).
The fact that the the tranny light and the cluster showed issues leads me to think that it is in an area up-stream of both or common to both.
A greater systemic connection issue or ground issue could cause weirdness as the signal is not strong to begin with too.
I would still clean the sensor.
Richard
chzuck
2004 - 2008 F150
Aug 16, 2015 11:32 PM
dmpruss
Jun 4, 2010 09:26 AM
Tater0519
Apr 12, 2005 07:33 AM
BOB6867
Feb 15, 2004 07:52 PM
