1997 Expedition to 1999 Navigator 2nd seat
Old Jan 20, 2017 | 11:08 PM
medhawk020's Avatar
medhawk020
I was wondering if it is possible to take the second row seats out of a 1999 Navigator and put them in my 1997 Expedition with a full bench??
Old Jan 22, 2017 | 08:40 AM
Kenzking's Avatar
Kenzking
Are you putting in the console and two captain chairs from a navigator, or a bench? The bench 60/40 seats should be the same between the two.
Old Jan 22, 2017 | 12:40 PM
medhawk020's Avatar
medhawk020
I want to put in the conole and the two bucket seats out of the Navigator
Old Jan 23, 2017 | 08:54 AM
Kenzking's Avatar
Kenzking
The center console is held in by a bracket that bolts between the second and third row, and two front bolts going into the floor. You can pull up the trim piece between the second and third row easily enough on your expedition, and see if the two bolt holes are there for the bracket. They should be hidden under the carpet an inch or so. If they are there I would assume the front mounting bolt holes would be as well.
As for the seats the buckets were an option on expeditions,l so they might fit easily enough.
Hope that helps a little
Old Feb 5, 2017 | 10:19 PM
medhawk020's Avatar
medhawk020
thank you for the help
jwvb23
May 27, 2017 01:45 AM
73F100DENT
Mar 25, 2017 07:22 AM
dbu8554
1997 - 2003 F150
Mar 10, 2009 04:42 PM
aklim
Aug 24, 2008 08:52 PM
drv
Jan 30, 2004 10:57 PM
