1997 Expedition to 1999 Navigator 2nd seat
The center console is held in by a bracket that bolts between the second and third row, and two front bolts going into the floor. You can pull up the trim piece between the second and third row easily enough on your expedition, and see if the two bolt holes are there for the bracket. They should be hidden under the carpet an inch or so. If they are there I would assume the front mounting bolt holes would be as well.
As for the seats the buckets were an option on expeditions,l so they might fit easily enough.
Hope that helps a little
jwvb23
05-27-2017 01:45 AM
shaneandsarah
1997-2006 Expedition & Navigator
03-25-2017 07:22 AM
aklim
08-24-2008 08:52 PM
