Startup RPM question
Old Sep 25, 2016 | 06:20 PM
crandallf150's Avatar
crandallf150
302 EFI all original stuff,when I first start her up the rpm's soar up for about 20 seconds and then drop back to idle which is too low considering the engine temp,not familiar with the efi on these trucks is there a process of elimination I can go through to get her running smooth?
Old Sep 25, 2016 | 08:34 PM
ctubutis's Avatar
ctubutis
Not a process of elimination, but a process of diagnosis - pull the codes from the computer, here's one write-up on doing that:
Ford Ranger - Testing EEC-IV Equipped Engines
Old Sep 25, 2016 | 08:44 PM
86Stepside's Avatar
86Stepside
Fast idle for 30 sec or so at cold startup is normal, but check for codes as ctubutis said, the computer should tell you whats going on.
Old Sep 25, 2016 | 08:59 PM
Franklin2's Avatar
Franklin2
Pull the wiring plug off on the idle air control. Then start it up. With a fully warmed up engine you want to set the idle screw so the engine idles very slow, almost too slow. Then when you plug in the idle air control the computer will add a little bit to it. After you do all this you will need to drive a couple of days till the computer re-adjusts itself.
P.S. If when you unplug the idle air control, you turn the idle screw all the way back, and it still is idling(you should be able to stall it with the screw) then you have a large air leak somewhere.
97ranger xlt
1983 - 2012 Ranger & B-Series
Oct 13, 2011 09:51 AM
JHowey1989
Aug 12, 2011 07:03 AM
aurgathor
1978 - 1996 Big Bronco
29
Mar 28, 2005 12:05 PM
Bryan Whited
Nov 28, 2002 02:25 PM
cookieman
Nov 20, 2002 06:37 AM
