1966 F600 MH questions
Long time listener, first time caller
. I'm hoping to get ahold of a MH F600, but I'm having a hard time finding medium duty information for decoding the data plate (or information in general). I figured if I would be able to get that information anywhere it would be here. Here's what I've got so far (please correct anything that I may have gotten wrong):VIN: F61BK760***
Truck Series: F61 - F600
Engine: B - 300 1V (65-66)
Assembly Plant: K - Kansas City, MO
Production Sequence: 760*** - Oct, 1965
DATA PLATE:
W.B.: 156
Color: *blank*
Model: F615 - 65-66 4WD F-600
Body: 481 - 4=Black all vinyl, 81=81A Standard Cab
Transmission: A - NP435 4 speed
Axle: 76 - ???
Max GVW Lbs: 24000
Cert. Net HP: 150
R.P.M.: 3600
DSO: 720027
One thing I'm confused by (other than not being able to figure out the axle code) is from what I've seen, MH conversions usually have a character next to the axle code which denotes the front axle rating. I am pretty sure it's a real MH (all the rivets seem original on the MH tags on the cowl, decals are there, the components don't look fussed with, etc). Is there a way to identify the front axle?
I got interested in it because I dig the thing, however I have a few questions out of curiosity's sake. How rare are these things? Is it insanely difficult to locate parts for these axles? This particular truck happens to have air brakes (which I've never worked on) and I don't want to run into a road block after I buy the thing.
I'll be going back to give it a better look next weekend. Is there anything in particular anyone can suggest to look out for which may tank this project, especially medium duty specific stuff, before it gets off the ground? Thanks!
. I'm hoping to get a hold of a Marmon-Harrington F600 4WD conversion, but I'm having a hard time finding medium duty information for decoding the data plate (or information in general). I figured if I would be able to get that information anywhere it would be here. Here's what I've got so far (please correct anything that I may have gotten wrong):VIN: F61BK760***
Engine: B - 300 1V I-6
Warranty PLATE:
W.B.: 156
Color: *blank*#
F-600Body: 481 - 4=Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81=81A Standard Cab
Axle: 76 = Timken model H140 Single Speed Rear Axle* / 4.63-1 / 17,000 lbs. Rear Axle Capacity.
24000 lbs. Gross Vehicle Weight Rating.
Cert. Net HP: 150 / R.P.M.: 3600
DSO: 720027:
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
0027 = Domestic Special Order# number, truck special ordered by the original purchaser, not "bought off the lot."
MODEL code F615 decodes to: F600, 24,000 lbs. Gross Vehicle Weight Rating.
*This rear axle has probably been changed by Marmon-Harrington, as the front and rear axle ratios have to match.
#When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
It's also possible that the Domestic Special Order number refers to the M-H conversion.
If the purchaser requested it, Ford would have sent the truck out...after it left the assembly line...to M-H (Indianapolis) to be converted.
Chucks Trucks LLC., Chuck's Trucks, Chucks Trucks
which denotes the front axle rating. I am pretty sure it's a real MH (all the rivets seem original on the MH tags on the cowl, decals are there, the components don't look fussed with, etc). Is there a way to identify the front axle?The AXLE code stamped on the Warranty Plate has nothing to do with M-H .. as the truck is a conversion that was performed after it left the assembly line.
AFAIK, M-H is still in business, but finding out which front driving axle they used will be difficult.
These trucks are money pits, are only worth what people are willing to pay for them.
I'll try to call Chuck here soon and see if he has any patience for my ignorance of these beasts. Thanks for the recommendation.
changed. A conversion was done seemingly some time ago to heavier Rockwell axles with 10 lug hubs, power
steering, and air brakes. I was rather impressed at the quality of the conversion. The only clues I had
that the conversion wasn't original were bolts in the front spring mounts instead of rivets and home made u-
bolt plates on the rear axle. The guy that owns it doesn't know much about it, but they mentioned something
about having "military axles," whatever that might actually mean. Since I've never seen these axles before
nor can I locate any information about them, here's the information I got from the tags on the axle housings:
FRONT: Model - FH150 HX17 / Ratio: 7.17
REAR: Model - H140 NX17 / Ratio: 7.20
There is some more information on the tags but I can't read what it refers to. Tag and axle pics are below
for anyone interested. At least I know that it's not untouched so I won't feel bad if I decide to modify
things a bit. The transfer case is Rockwell, but I'm not sure if it is the one that would have come with the truck or not. If anyone sees anything of note, I'd love any more information anyone might be able to pass on.
Now I just have to figure out what to offer the guy...
Sam
