1997 power Window Problem
Old 08-19-2003, 06:18 PM
timlb's Avatar
timlb
timlb is offline
I got a 1997 Extended Crew Cab Lariat. All of a sudden my power window on the driver side has stopped working. Worked just fine the night before. Now all I get is a CLICK at the relay. The passenger works just fine. Any ideas?
Old 08-19-2003, 11:14 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Hi Tim and welcome to FTE
The click means that the switch is probably ok. I'd bet your window motor has died and will need to be replaced. Before you do that though make sure that you have power to it in case you have a broken wire or something. You'll have to remove the door panel to get at the connector and check for power with a test light while working the switch.
Old 08-20-2003, 09:57 PM
timlb's Avatar
timlb
timlb is offline
How hard is it to remove the motor on this model year truck? I've read some stories about having to drill to reach bolt heads..etc. but wasn't sure what model they were referring to.
Old 08-21-2003, 09:28 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Up in the FAQ's at the top of the page is info on removing your door panel. Once that is off you'll see the 3 dimples you need to drill out to remove the screws that hold the motor on. The manual says to use a 3/4" hole saw but I've managed to just use a 1/2" drill and a thinner socket.
Old 08-22-2003, 07:15 PM
timlb's Avatar
timlb
timlb is offline
Here's a twist. The window works at night or after a rain storm.
Old 08-26-2003, 10:54 PM
BIGTONY1973's Avatar
BIGTONY1973
BIGTONY1973 is offline
Sounds like a gem problem... The windshield leaks onto and into the gem on the back of the fuse block causing all sorts of weird electrical problems with wipers, windows, etc..
BigT
guppyboy
Electrical Systems/Wiring
08-28-2012 03:52 PM
gdennis51
05-22-2009 02:11 PM
rooboy
06-29-2008 12:34 AM
brianb728
1997 - 2003 F150
07-08-2007 02:15 AM
a64armt
1997-2006 Expedition & Navigator
06-01-2006 07:38 PM
Quick Reply: 1997 power Window Problem
