Sponsored by: Auxito
1997 power Window Problem
Old Aug 19, 2003 | 06:18 PM
timlb's Avatar
timlb
I got a 1997 Extended Crew Cab Lariat. All of a sudden my power window on the driver side has stopped working. Worked just fine the night before. Now all I get is a CLICK at the relay. The passenger works just fine. Any ideas?
Old Aug 19, 2003 | 11:14 PM
Racerguy's Avatar
Racerguy
Hi Tim and welcome to FTE
The click means that the switch is probably ok. I'd bet your window motor has died and will need to be replaced. Before you do that though make sure that you have power to it in case you have a broken wire or something. You'll have to remove the door panel to get at the connector and check for power with a test light while working the switch.
Old Aug 20, 2003 | 09:57 PM
timlb's Avatar
timlb
How hard is it to remove the motor on this model year truck? I've read some stories about having to drill to reach bolt heads..etc. but wasn't sure what model they were referring to.
Old Aug 21, 2003 | 09:28 AM
Racerguy's Avatar
Racerguy
Up in the FAQ's at the top of the page is info on removing your door panel. Once that is off you'll see the 3 dimples you need to drill out to remove the screws that hold the motor on. The manual says to use a 3/4" hole saw but I've managed to just use a 1/2" drill and a thinner socket.
Old Aug 22, 2003 | 07:15 PM
timlb's Avatar
timlb
Here's a twist. The window works at night or after a rain storm.
Old Aug 26, 2003 | 10:54 PM
BIGTONY1973's Avatar
BIGTONY1973
Sounds like a gem problem... The windshield leaks onto and into the gem on the back of the fuse block causing all sorts of weird electrical problems with wipers, windows, etc..
BigT
guppyboy
Electrical Systems/Wiring
Aug 28, 2012 03:52 PM
gdennis51
May 22, 2009 02:11 PM
rooboy
Jun 29, 2008 12:34 AM
brianb728
1997 - 2003 F150
Jul 8, 2007 02:15 AM
a64armt
Jun 1, 2006 07:38 PM
