2 remaining leaks..what are these????
6L Turbodiesel
I still have this returning oil drop on the oil pressure regulator. That fluid does seem to be oil.
Now I found what appears to be coolant dripping off the power steering pump. I have had to add a small amount of coolant every week...not much but definitely noticeable.
I have a new OPR which I will replace. Any other ideas? These pics are from looking up at the mail pulley and to the left (power steering)
You look like coolant as you stated... have you looked at the tee fitting for your aftermarket coolant? That's where mine leaked for a long time until I got the right clamps on it. Having to add coolant every week may not seem like a lot but it is. do you have any puddles in the driveway? Can you smell it after driving like its spraying under pressure?
