Sponsored by: Auxito
'99 F150 4x4 Won't start, ABS light on
Old Jul 27, 2016 | 08:30 PM
Macamon's Avatar
Macamon
I did my due diligence and cant find anything in forums, so...
My son's 99 F150, 4.7L 6cyl 5 speed 4x4 will not start, no code, ABS light is on.
Changed the ABS sensors out, can't figure out why it's doing this.
Old Jul 27, 2016 | 08:48 PM
steve(ill)'s Avatar
steve(ill)
ABS has nothing to do with ignition.
You need fuel and spark. Put the key in the ignition and turn to "on" not start... The THEFT light will come on for 3 seconds, computer will match the key code to the truck and light will go out.......... at the same time the fuel pump will start and run for 3 seconds and build up pressure in the rail... you should hear the pump start if you listen closely... RESULTS ?
Old Jul 27, 2016 | 09:22 PM
Macamon's Avatar
Macamon
Alright, I'll start there, will be a couple days before I have time to attack it. I'll be in touch then, for now... why does it say ill next to your name friend? what's going on?
Old Jul 28, 2016 | 08:06 AM
steve(ill)'s Avatar
steve(ill)
Illinois ..............
Old Jul 28, 2016 | 08:09 AM
steve(ill)'s Avatar
steve(ill)
when you turn the key to "ON", the ABS light comes on also.... When you start the truck and continuity type test is run and if all the wires and sensors are connected, the light goes out........... When you start moving over 5 mph another test is done to see if the sensors are sending back speed signals... if not, the light comes back on............ but that has nothing to do with the ignition.
big60
1997 - 2003 F150
32
Dec 19, 2013 04:33 PM
lilman320
1997 - 2003 F150
Jan 25, 2011 06:31 PM
93F250
Mar 23, 2008 07:02 AM
Metacarpels
1997 - 2003 F150
Sep 30, 2004 11:35 AM
