Carb gurus please help
Old May 6, 2016 | 11:39 PM
gijazbo's Avatar
gijazbo
So i bought a replacement fro my Motorcraft 2150 from National carb. My old one was a 2150 with electric choke assist on a 1978 F-150 with a 351M Auto and 4x4.
Below are the pictures of what came off and the one they sent me. they both seem to be 2150s, but they have several differences.
I just want to know if i can slap this thing on plug up the un-needed vacuum ports and be good.
also, the power valve on the bottom is the tall version and will not clear my EGR spacer. Can i just swap my short one in ?
Any help is appreciated.
Different ribbing and ports.
/diffferent /thorrtle linkage with that white rollwer thing.
Added vacuum ports
Different linkage.
Tall power valve and open port.
Old May 7, 2016 | 07:43 PM
gijazbo's Avatar
gijazbo
bump for a poor soul in need
Old May 12, 2016 | 10:53 AM
gijazbo's Avatar
gijazbo
I have been searching FTE and google for a few days and I'm still no closer. If anyone has any insight it would be much appreciated. Even if its just a bit of the info I am looking for. Thanks in advance
Old May 12, 2016 | 11:22 AM
brianto79's Avatar
brianto79
You should be able to plug the extra vacuum ports. Swap in the short egr valve and your good to go.
Old May 12, 2016 | 02:27 PM
earthquake68's Avatar
earthquake68
I wish all the carb swaps I did where that close. It'll work just fine. Just plug the extra ports and run with it. The white roller thingy on the linkage is for a truck with cruise. The extra ports are just that. Extra. If you don't need them, cap them off. Swap that giant power valve housing for your small one, bolt on and go.
Old May 12, 2016 | 04:59 PM
gijazbo's Avatar
gijazbo
You guys rock!. Thank you. I had a limited window to return the unit ... and you can't install it and return... so i was hoping someone would shine some light. Thanks Again!!
Old May 12, 2016 | 06:13 PM
whiskey runner's Avatar
whiskey runner
like alan said plug up the extras!!!.. maybe on the taller power valve cover you could just use one of the thicker (isolater) type gaskets.. they do help keep the carb cooler also
Old May 12, 2016 | 06:26 PM
4x4slik's Avatar
4x4slik
I only saw one extra port, but maybe I missed something. I agree though, just plug it and swap out the power valve cap and you should be good.
Old May 12, 2016 | 08:55 PM
Blue and White's Avatar
Blue and White
I've had similar issues with reman carbs... especially extra ports. I always plug them and run it and has worked out fine.
jason867
26
May 3, 2017 04:49 PM
willowbilly3
1947 and Older Ford Trucks
Feb 22, 2016 09:02 AM
fordboy300
17
Dec 18, 2014 12:18 PM
Steve Christensen
Nov 3, 2013 09:36 AM
