Wire Firing Order & Coil requirements
Old Mar 28, 2016 | 11:35 PM
BillyV's Avatar
BillyV
I acquired a 1973 302 with no plug wires and the distributor was sitting loose in the hole.
Thus, I'm looking for advise on my motors firing order…. and I would also like to get recommendations for the correct coil requirements and what separates one coil from another.
Thanks, Bill
Old Mar 28, 2016 | 11:59 PM
52 Merc's Avatar
52 Merc
Welcome to the forum! The firing order for a 73 302 is 15426378. It looks like this...
If you have the original points-type distributor still, just get a stock replacement coil from your local parts store. Same for wires. High performance coils have a higher voltage discharge that works better in high compression applications, but for a stock engine, it's not necessary.
You'll want to make sure the distributor is installed correctly so your timing is where it should be. It's a little trickier than I can explain quickly in a forum post. You might find a youtube video if you're totally lost.
Old Mar 29, 2016 | 12:33 AM
Mervy49's Avatar
Mervy49
An easy way to get the number piston up close to top dead center is to take out the spark plug on number one cylinder. Put your thumb on the hole and have a friend handy to turn the engine clock wise facing with a socket on the front crank pulley. You will feel the piston push air against your thumb. You can generally tell when the piston reaches or get close to TDC. Try it a couple times to get the feel. Make sure the rotor in the cap is pointing at no. 1 (after) when you drop the distributor into the hole. When the engine fires turn the distributor slowly both directions by hand until it starts wanting to run. You will want to have number one piston just slightly a little bit before top dead center. Should fire up, Follow Wayne's advice above. Hope this helps.
Old Mar 29, 2016 | 10:00 AM
Mixer man's Avatar
Mixer man
(That's clockwise as if you're standing in in front of the vehicle looking at it).
Old Mar 29, 2016 | 10:30 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
No, it is counter -clockwise, (look at Wayne's diagram) it don't matter where you are, counter-clockwise is counter-clockwise
Old Mar 29, 2016 | 12:38 PM
04Z06Vette's Avatar
04Z06Vette
Not to confuse you, but the firing order mentioned is correct for a 302 with stock cam of that era. There are some 302s that use a different firing order (302HO for one)and many of the aftermarket cams including the edelbrock performer use the other firing order. it is 13726548.
Old Mar 29, 2016 | 12:50 PM
Mixer man's Avatar
Mixer man
And the distributor always turns counter-clockwise.
Old Mar 29, 2016 | 01:04 PM
Mixer man's Avatar
Mixer man
And FYI: All engines are standard SAE left-hand (counter-clockwise) rotation, looking at the flywheel, unless they are changed to right-hand rotation for marine applications. Right-hand (clockwise) rotation is standard for all single phase electric motors.
Old Mar 29, 2016 | 01:07 PM
Mixer man's Avatar
Mixer man
Sorry. I was just trying to justify Mervy49's post.
Old Mar 29, 2016 | 08:48 PM
52 Merc's Avatar
52 Merc
Not to further confuse the issue, but one person was talking about the distributor turning counter clockwise, while another was talking about engine rotation, which is clockwise looking at the front of the engine. So everyone is right. Gold stars all around.
Old Mar 29, 2016 | 08:53 PM
Flat Ernie's Avatar
Flat Ernie
As mentioned, there are two firing orders for the small block Ford.
1-5-4-3-6-2-7-8 was standard on all 221/260/289/302 until 1982 or so...
The 351W and 302HO use the other firing order: 1-3-7-2-6-5-4-8
However, either cam may be used in either engine so long as the firing order is swapped to reflect which camshaft it has. The rumor is that Ford changed the firing order on the 351 and later 302 due to the consecutive firing impulses on the first rod journal (1 & 5).
If your engine is stock, or appears stock, the odds are it is the 1-5-4... firing order. But it's easy to figure out - pull the valve covers and rotate the engine.
Old Mar 29, 2016 | 09:12 PM
Mervy49's Avatar
Mervy49
That's why I said 'facing", heh heh, I guess I could have been clearer with my explanation.
Old Mar 30, 2016 | 11:44 PM
BillyV's Avatar
BillyV
THANKS everyone
Tekmon1
Jan 17, 2018 11:16 AM
cocreator69
Feb 6, 2012 06:09 PM
black58
35
Nov 22, 2010 11:43 AM
gambianer
Sep 13, 2005 01:53 PM
Nitro
Aug 16, 2002 11:28 AM
