72 F250 engine trouble
This is my first thread and am really looking to get some good advice as I'm doing all the work myself (ouch!) I've never attempted this before and since it is an older model vehicle I look forward to the challenge.
My problem:
I don't know anything about getting top-dead-center, I borrowed the tools necessary for the job though. I know the line-up of plugs to the cap (I bought a new distributor and new carb) which is a holley 2 barrel. Without sounding completely clueless I just need to get this thing going and the more help I can get from my fellow enthusiasts the better.
I checked my points and the gap is correct (17), I turned the distributor so that it was on the number one wire for the plug, but now it just backfires on me. So now I'm stuck and need some help.
Thanks for any advice you can offer me!
Make sure your plug wires are correct...are they wired up according to the firing order for your motor?
Find the No. 1 cylinder...on a 360 V8 this is the front, passenger side cylinder.
Pull the plug and plug wire from that cylinder.
Find the timing marks on your crank pulley...the bottom pulley. You may have to crawl under the truck to do this...clean the marks off with steel wool or sandpaper and then rub some white chalk over them.
Put a big socket on the nut of the crank pulley...rotate the engine by hand with the socket and a wratchet or bar until the 0 timing mark is right by the timing marker on the top of the pulley. It should be marked TDC/0.
To find the compression/firing stroke of that cylinder/piston, put your thumb/finger over the plug hole and have someone turn the engine by hand with the socket/wratchet. When the No. 1 cylinder is on its compression stroke, you will feel air pressure building up under your finger/thumb...if not, the engine is on the exhaust stroke and you have to keep turning the engine.
After you find the compression stroke, turn the socket/wratchet until 0/TDC shows next to the timing pointer.
Pull the dist. cap and make sure the rotor is pointing to the No. 1 tower on the dist. cap. If it's off and pointing to another tower, you need to pull the distributor up turn it and reseat it so the rotor is pointing to No. 1. Then tighten the dist. hold down bolt.
Now double check your wire connections on the dist. cap and spark plugs, and make sure the plug wire routing matches the firing order.
That's how you do it using Ford's "official" firing order recommendation.
In reality, the engine doesn't care which dist. cap tower or wire you use to fire any of its cylinders...it just wants fire in the correct sequence/firing order. So if you find that the rotor is off a tower or two after you find TDC on the compression stroke, that's okay, too. Simply route your plug wires according to the firing order, using that tower as a starting point for the No. 1 cylinder...wire that one to No. 1, then follow the firing order to get the other dist. cap towers/plug wires to the correct cylinders.
The only thing I just can't get is the timing light and the dwell meter. I understand the concept but I can't hook up the timing light to the plug, and is there another place to put the dwell meter instead of the coil? another spot maybe? I don't seem to have a way to hook it up to the coil.
2V.
