Blank Gauge
Old Mar 5, 2016 | 10:55 AM
Norfra's Avatar
Norfra
Smile Blank Gauge
Hi guys i just got my Ford Dealer to program 2015 F 250 to show the DEF gauge .
( I found the instructions here on this site Great site by the way)
It shows different % levels on the gauge ? when I check it. My dealer did fill it up at the time of the service. Does the computer need time to adjust to this change. it shows 65% now and I know it is full, When I first pick up the truck it showed 85%.
Old Mar 5, 2016 | 12:09 PM
swarf_rat's Avatar
swarf_rat
DEF gauge? Are you sure that isn't the DPF gauge? Two different things. The DEF gauge is always there in the information display, but only shows half full, quarter full, and empty AFAIK. The DPF gauge that the dealer turns on shows %, climbs till it hits 100% and then you get a regen.
Old Mar 5, 2016 | 03:22 PM
Norfra's Avatar
Norfra
Thank you This is my first diesel.
Love my Ford
Norm
Old Mar 5, 2016 | 10:04 PM
tracyclifton's Avatar
tracyclifton
I don't know about the factory gauge but the TorquePro gauge shows DEF level in gallons. I thought it was pretty accurate but the last time I filled up I had 2.0 and added 2.5. Then it read 3.1. TorquePro also displays soot level (DPF) 0%-100%. If the ECU transmits this info I would assume you could get it activated on the blank screen.
Old Mar 5, 2016 | 10:36 PM
Dakster's Avatar
Dakster
You had 2.0 added 2.5 - shouldn't that be 4.5 and not 3.1? Or is this common core math?
Old Mar 5, 2016 | 10:41 PM
tracyclifton
That's too simple for common core. Yes it should be 4.5 but for some reason it only went to 3.1. Maybe it really only had .6 when I added 2.5, and the 2.0 was a lie. Either way, I know it had at least 2.5 in it after I added the new 2.5 jug. The rest may be a mystery for the ages.
Old Mar 6, 2016 | 05:11 AM
Rattler1's Avatar
Rattler1
The DEF level on my EDGE CTS is all over the place too. I guess the way the stuff crystallizes may have some effect on the accuracy of the sensors.
I usually just go by the message that pops up on the dash that tells you when it is close to empty - but that isn't super accurate either. I loaned my truck to some friends because their car was in the shop. He told me the DEF message came up a couple times but when I picked it up the message wasn't coming up. I put some DEF fluid in anyway.
Old Mar 6, 2016 | 10:15 AM
swarf_rat's Avatar
swarf_rat
The % soot level is provided by the PCM and can be read by any OBD scan device. However it does not directly correlate to the dashboard indicator on my truck. It is loosely correlated. The DEF tank only has sensors for half full, quarter full and empty, not a linear sensor like a fuel gauge. Anything finer information is interpolated (or guessed) based on other operating time etc.
Old Mar 6, 2016 | 05:44 PM
Just Strokin's Avatar
Just Strokin
There is not a symmetrical gauge system on the DEF tank. Using the CTS or TorquePro to get tank level is not worth the effort. There only 2 or 3 level sensors in the tank.
jimm66
1997 - 2003 F150
Jun 1, 2008 08:48 PM
rivrrunner
Mar 31, 2008 08:45 PM
DieselRunner
Jun 6, 2007 01:24 AM
