Recommendations parts cleaning solvent ?
Old Jan 31, 2016 | 08:27 PM
JRS2's Avatar
JRS2
Finally purchased a parts cleaning machine and it appears there are a few choices of solvents to use. Old days with a tub and no circulation pump I have used diesel fuel or kerosene, but those are probably out with an electrically driven pump system. Agree ? Wondered what concoctions others have used with success ? I am thinking heads and other smaller parts, some of which may have some rubber seals at times .....
Old Jan 31, 2016 | 08:40 PM
whisler's Avatar
whisler
A friend uses a water-based cleaner called "Mean Green" in his tank, Works well for him, but he warned me not to leave aluminum parts in it over night. Don't ask how he knows!
Old Jan 31, 2016 | 09:18 PM
sgip2000's Avatar
sgip2000
I use paint thinner for most cleaning.
Old Feb 1, 2016 | 07:56 AM
'89F2urd's Avatar
'89F2urd
most degreaser chemicals are combustable, so theres no reason you couldn't use diesel in a system designed for more volatile chemicals. diesel is not easy to ignite, relatively speaking.
I like to use water based solutions whenever heavy stuff is not needed. This method is not only cost effective, but I'm really not a fan of being overly exposed to chemicals that will make the asbestos-esque "we didn't know it'd give you a slow and terrible death" list 25 years from now.
Old Feb 1, 2016 | 10:18 AM
HrdDrv's Avatar
HrdDrv
Worked with several commercial parts cleaning products, and when they did their monthly fluid change-over, for the next 2 weeks my hands would crack and bleed until the solvent would get 'mellowed' out. An old salt mechanic, went to the parts shelf, grabbed a bottle of trans fluid, and 'conditioned' it. No more cracks or bleeding. Diesel and Kerosene is a natural hand softener opposed to gasoline and such. Lower flash point, safer storage, etc. Pumps used in parts washers are double insulated and designed for immersion in the solvent, as is fuel pumps in fuel tanks.
Old Feb 1, 2016 | 01:59 PM
katrinemarine's Avatar
katrinemarine
Check to see that your new parts washer is rated for solvent based cleaners. You didn't say what brand or where you bought it but many of the inexpensive Harbor Freight, Princess Auto (Canada) units are only suitable for water based cleaners.
Old Feb 1, 2016 | 06:13 PM
JRS2's Avatar
JRS2
Wisdom brand made in Taiwan, guess price was more important than quality, and my forecasted parts list
Old Feb 1, 2016 | 06:17 PM
JRS2's Avatar
JRS2
Whisler, you do not mean Simple Green, is this correct ? Anyone ever use this ? Not sure that it would handle heavy duty jobs but it seems to work well on lesser amounts of cake greased parts ....
Old Feb 1, 2016 | 06:21 PM
JRS2's Avatar
JRS2
Ok, do you use this in a parts tub with a circulating pump or just with parts cleaning brushes ? I believe that has a high or low ? flash point, in any case quick evaporation, would you agree ?
Old Feb 1, 2016 | 09:44 PM
whisler's Avatar
whisler
Not "Simple Green", But "Mean Green". I think I bought mine at Walmart. You can clean your hands in the tank and suffer no ill effects, as long as you rinse it off. My friend does a lot of resto-work on old trucks and tractors and it is about all he uses except for a small can of lacquer thinner for really tough stuff.
Old Feb 1, 2016 | 09:49 PM
JRS2's Avatar
JRS2
Ok, just making sure. Now I'll have to do some research. Thks
Old Feb 1, 2016 | 11:16 PM
wtroger's Avatar
wtroger
Mineral spirits (paint thinner) it has high flash point. It will burn but you have to work at it to set it on fire. It leaves parts clean and dry.
Old Feb 2, 2016 | 08:52 AM
roboto65's Avatar
roboto65
Still use Varsol works great about 7 dollars a gal.
Old Feb 2, 2016 | 10:08 AM
78 PEB's Avatar
78 PEB
Yup.......works every time! I don't know if it still does but the old ATF actually had Lanolin in it.
Eastpark
Garage & Workshop
27
Aug 3, 2005 10:17 PM
Okiedokie
May 4, 2005 05:08 PM
Ford79
Garage & Workshop
30
May 18, 2004 04:41 PM
angus
Garage & Workshop
Sep 21, 2002 07:32 PM
72stepside
Garage & Workshop
Aug 5, 2002 03:57 AM
