How to seal up the 3 speed toploader
Old Oct 4, 2015 | 07:17 PM
dlb.motorman's Avatar
dlb.motorman
I have rebuilt the floor shift three speed toploader transmission in my 1950 F1. I have found a small leak that I'd like to get sealed up some how. It appears to be coming from the area where the transmission gear shafts are supported at the rear of the case. There is a locking rod and cotter pin in the same area. The oil seems to be coming from that general area and then runs down the bottom of the case, accumulates around the drain plug and then drips off. The oil, a combination that is supposed to replicate the 600W oil that was originally used, slowly over time drips a small puddle on the floor.
I don't recall any seals for the ends of those shafts. Has anyone else experienced this issue?
Old Oct 4, 2015 | 07:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Not sure where you saw that 600 wt oil was spec'd or used originally, just not so. SAE 140 was spec'd. Most people use 85w140 nowadays, GL-4.
Is your trans still out? About all you can do to attempt to seal those shafts is to push them forward slightly (with the lock rod out), degrease thoroughly, wipe on some Loctite sealant or RTV in the hole, and push the shafts back. You for sure do not want to push them far enough forward that they go completely out of the case!
Old Oct 4, 2015 | 07:57 PM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
I have pretty much abandoned the idea of getting my old F-2 to quite seeping oil. The technology to keep them tight and dry just did not exist. If you can keep the oil loss to a few drops a month, you are doing well.
If you have a puddle, there may be an issue here, but a simple slick stain, typical of a healthy truck.
Old Oct 4, 2015 | 10:49 PM
1950FordF1's Avatar
1950FordF1
I have used the newer shafts In my V8 trans.
They are made to accept an o-ring to provide the seal.
Old Oct 4, 2015 | 11:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Do you have the p/n's for the newer style shafts, or the applications?
Old Oct 5, 2015 | 05:50 AM
dlb.motorman
Sorry for the confusion ALBUQ-F-1. 600W was a nomenclature for Mobil's oil spec, it is not 600 weight. What I've used is a mixture between 90w-140w oils. Thanks all for your responses.
wb6anp
Apr 5, 2017 06:06 PM
Maltman
Dec 5, 2013 03:36 PM
ola1234
May 24, 2011 05:04 PM
spudgunman
Feb 6, 2010 03:37 PM
F250Rob
Nov 24, 2006 07:38 PM
