3 speed manual oil fill hole
12-04-2013, 10:25 PM
is this the hole on the passenger side half way up the case? I ask because my tail-shaft seal was leaking for a while...I just changed and removed that plug to fill with gear oil and oil was still running out, truck was level as well. any ideas?
12-05-2013, 07:00 AM
Should be. Proper level is at the bottom of the fill hole. If it runs out it is too full.
12-05-2013, 02:49 PM
I wonder how/if PO overfilled, the level had to drop from the tail shaft seal leaking-wasn't bad leak, but...hmm.
I guess I will just drain and refill to be on the safe side. Maybe over fill was cause of leak in first place?
12-05-2013, 03:01 PM
Be careful what gear oil you use, the new GL5 rated eats brass synchros. Try to find GL4..
12-05-2013, 03:10 PM
good info, will do. do you happen to know capacity?
12-05-2013, 03:17 PM
Quote:
Originally Posted by
Maltman
I don't remember exactly 2 or 2 1/2 pints, I just fill to the bottom of the hole.
12-05-2013, 03:36 PM
gotcha, just wondering how much to buy. will take care of soon
dlb.motorman
10-05-2015 05:50 AM
DrCharles
03-16-2012 11:44 AM
Sponge Bob
12-29-2010 08:05 AM
daner01
09-26-2010 04:26 PM
58fordF100
11-29-2009 08:40 AM
