Simple Question from a Simple Man - Resistor
Old Sep 15, 2015 | 09:19 AM
54TexasF100's Avatar
54TexasF100
I have searched here but can't seem to find a direct answer.
I have an electronic distributor and a 12 volt coil (both stock replacements to the 1985 Ford 351W). Do I need a ballast resistor? I created my own harness an installed this resistor (1.5?) because I thought I needed one. I haven't registered and insured my truck yet for highway use but have been danger driving it around my neighborhood for some time and haven't noticed an issue (aside from a very hot resistor). No lights or anything else wired up yet. Second question: if not needed, have I been robbing my spark? Before I just remove the resistor I wanted to ask so I don't damage something.
Stephen
Old Sep 15, 2015 | 09:49 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Most electronics do not need one. Is yours a Duraspark system?
52 Merc's Avatar
52 Merc
No resistor with electronic ignition. In fact, electronic ignition of all kinds likes and needs a full 12 volts. Resistors are only there to protect the points from burning. No points, no resistor.
Old Sep 15, 2015 | 10:12 AM
54TexasF100
Ross-Thanks. I have the Duraspark box as part of my system.
Wayne-Thanks.
I guess now I am surprised that my truck runs at all. I also wonder if I will notice a difference once I remove the resistor.
Old Sep 15, 2015 | 10:35 AM
52 Merc's Avatar
52 Merc
There are several wiring diagrams online for Duraspark II ignition. Here's one. No guarantee of accuracy on my part. It's just the first one I grabbed.
Old Sep 15, 2015 | 11:51 AM
Smitty49's Avatar
Smitty49
Duraspark II
Old Sep 15, 2015 | 12:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Duraspark uses a resistance wire, as described in Smitty's article, also shown in Wayne's diagram as a resistor. If you used an OEM harness, check the resistance of the wire feeding the coil.
Old Sep 15, 2015 | 12:52 PM
54TexasF100
So this is where I have been confused before. "No points, no resistor", however the duraspark ignition has a resistor. Would you have points and use the duraspark? The reason I installed the ballast resistor is because I used the same schematic as above to make my harness (not OEM). I am not sure what the resistor is for if my coil is 12V. Is the resistor somehow to protect the ignition module?
Old Sep 15, 2015 | 01:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-213) / Obsolete ~ Available NOS & from auto parts stores.
49" long / Color coded red with green stripes / 1.30 - 1.40 ohms resistance / #16 gauge wire.
1977/89 Passenger Cars, F100/350, Bronco & Econoline.
Besides this puppy, there are 3 others. One was used 1971/76 with/without DuraSpark.
DuraSpark electronic ignition introduced in 1974, but not all vehicles came with it until 1976.
94bonestocker
Electrical Systems/Wiring
Mar 18, 2006 11:14 AM
The67Beast
Aug 4, 2005 11:11 PM
ranchero73
Jul 8, 2004 09:42 PM
56f600
Oct 29, 2003 09:46 PM
deere81
Aftermarket Products
Oct 10, 2002 08:18 PM
