Swap 6 cyl to V8
Old 08-21-2015, 07:45 PM
awjjim's Avatar
awjjim
awjjim is offline
Swap 6 cyl to V8
I have a 1949 F4 with Flathead 6 cyl. Thinking about switching to Flathead V8. Would like to know what modifications I would have to make. A few items come to mind, motor mounts, bell housing, transmission, drive shaft modification, carb linkage and exhaust. Any ideas and suggestions.
Old 08-21-2015, 08:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I'm guessing you have a 4-sp spur gear trans? If so, you can keep the trans but need to use the V8 clutch cover (the 1/2 bellhousing attached to the block). Then motor mounts and exhaust, radiator, carb linkage. No driveshaft changes.
But you might want to consider a different trans anyway, depending on your intended use.
Old 08-21-2015, 09:07 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
The radiator mount positon also differs from the I6.
Old 08-21-2015, 09:59 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
If you are staying with six volt, you may want to move the battery to the passenger side.
Old 08-21-2015, 11:06 PM
51fred's Avatar
51fred
51fred is offline
Thumbs up
One of my trucks POs did the opposite. They took out the 8 and 3 on the tree and put in the 6 and spur gear 4 sp. At least they grabbed the floor trans cover as well.
I think the motor mounting hardware and rubber bits are the same for 6 & 8. Don't forget about the wind deflector under the hood. The 8 version I bigger as it is further back in the hood.
Old 08-22-2015, 07:58 AM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
JMHO, the six is a better choice for the truck. More torque where you need it. But, it does not have that cool V8 factor.
Old 08-22-2015, 09:47 AM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
You will need the air deflector in the hood and the one below in front of the radiator. You will also need a V8 battery tray which is on the passenger side and lower to the frame. The radiator will need to be moved back 3" to the V8 position, all the holes are already there. You will need a V8 radiator shroud. Motor mounts are the same, transmission is in the same position, but as Ross said you will need the V8 half bell or hogshead. The throttle linkage mounted on the firewall is also different. The starter solenoid is on the passenger side of the firewall in a V8 truck, but here again the holes are there for the move.
Old 08-22-2015, 11:05 AM
awjjim's Avatar
awjjim
awjjim is offline
Thank you all for decision making information. It sounds pretty straight forward with minimal fabrication.
Kirk-NJ
03-07-2017 03:09 AM
newguy399
12-28-2012 12:30 PM
ryanlewis03
10-08-2010 01:03 PM
js1720
02-23-2009 09:57 PM
dbiscayne
1966 - 1977 Early Broncos
01-14-2007 12:37 AM
Quick Reply: Swap 6 cyl to V8
