flathead engine swap
Old Mar 5, 2017 | 10:05 AM
Kirk-NJ's Avatar
Kirk-NJ
Have a '51 ford pickup with flathead 6. Can I take that out and bolt in a flathead V8. Will the bolt holes line up in the bellhousing with the V8 engine? Easy swap?
Kirk
Old Mar 5, 2017 | 11:22 AM
ALBUQ F-1's Avatar
ALBUQ F-1
It's as easy as they get, just need to go back with stock parts:
-- V8 clutch cover
-- move radiator back to V8 location, and replace with V8 radiator
-- air deflectors under the hood are different and further back on V8
-- air deflector in front of the bottom of the radiator is deeper on V8
-- buy the appropriate V8 motor mounts
-- the battery was on the opposite side on V8's
-- fuel line is very different
-- engine electrical needs modification
-- different throttle linkage
Old Mar 6, 2017 | 04:55 AM
Kirk-NJ's Avatar
Kirk-NJ
Thanks for the reply. My concern was the bellhousing lining up. the rest is small stuff. Now we are good to go.
Thanks, Kirk
Old Mar 6, 2017 | 05:01 AM
Kirk-NJ's Avatar
Kirk-NJ
Ok, rereading your post, is the clutch cover what you consider the bellhousing? If so then the V8 won't mount without a change, correct?
Thanks, Kirk
Old Mar 6, 2017 | 09:08 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The clutch cover is the ring-shaped piece that bolts to the engine. What model is your truck? What trans do you have now? Regardless, from the clutch cover back, everything is the same whether it's a 6 or V8.
Old Mar 6, 2017 | 09:55 AM
firstrider's Avatar
firstrider
Have a spare clutch cover if you have a hard time finding one near you . Plese post your location .
Old Mar 6, 2017 | 11:07 AM
pezsox's Avatar
pezsox
I need a exhaust manifold for a flathead 226 if you have one you won't be using.
Old Mar 7, 2017 | 03:06 AM
Kirk-NJ's Avatar
Kirk-NJ
Now I've got it. Thanks
Old Mar 7, 2017 | 03:07 AM
Kirk-NJ's Avatar
Kirk-NJ
My cousin is using the whole engine for something else
Old Mar 7, 2017 | 03:09 AM
Kirk-NJ's Avatar
Kirk-NJ
I believe I have everything I need. If not I will let you know thanks.
cowdog86
Jan 6, 2017 09:19 PM
lobsterbak
13
Sep 4, 2010 09:30 PM
rmann54
Nov 3, 2007 04:47 PM
48 F-2
Engine Swaps
Oct 19, 2004 04:23 PM
skeleton33
May 17, 2004 02:08 PM
