1983 F150 300 6cyl running on only 4 cylinders
Old Jun 12, 2015 | 02:08 AM
Tommy Ride's Avatar
Tommy Ride
Hi I've got a 1983 F150 300 6 cylinder running on only 4 cylinders. Happens to be the first 2 cylinders, 1 & 2 not working. I tried swapping spark plugs (known good ones, and swapped out spark plug wires & cap & rotor.) I'm wondering what it might be, what to, and where to go from here. Thanks for any ideas & help.
Old Jun 12, 2015 | 05:20 AM
maytag906's Avatar
maytag906
Do a compression test.
Old Jun 12, 2015 | 07:53 AM
1986F150six's Avatar
1986F150six
X2 what maytag906 said. The head gasket may have blown between #1 & #2.
Welcome to the forum, Tommy Ride!
Old Jun 15, 2015 | 03:59 PM
Tommy Ride's Avatar
Tommy Ride
Thanks Maytag and 1986. Will do a compression test soon. As far as head gasket blown 1986, I'm not getting any steam or water in the oil which I thought would be the case with a blown head gasket. Thanks.
Old Jun 15, 2015 | 06:49 PM
ctubutis's Avatar
ctubutis
The gasket can also be blown between the two adjacent cylinders, that wouldn't involve mixing the oil & water.
IOW water in the oil/oil in the water *can be a symptom of* a blown head gasket but isn't necessarily a symptom....
Other possible causes are sticking or burned valves, or bent pushrods, or....
Old Jun 15, 2015 | 10:43 PM
Tommy Ride's Avatar
Tommy Ride
thanks ctubutis for the info/knowledge.
Old Jul 13, 2015 | 08:53 PM
Tommy Ride's Avatar
Tommy Ride
Compression Test
Okay, just did a compression test on all 6 cylinders, from front to back compression was:
1. 97
2. 120
3. 130
4. 130
5. 130
6. 125
What should the compression be, taking into account it is an older vehicle?
Obviously 1st cylinder is way below the others, and number 2 is below the other 4. I just took the valve cover off. Nothing seems way out of wack, no nuts are off the rockers or anything. What does this suggest is wrong and wondering what to do from here. Thinking next step would be to remove the head. How can I tell the difference between bad valves, blown head gasket and bad rings in piston? Thanks.
Old Jul 14, 2015 | 08:16 AM
ctubutis's Avatar
ctubutis
A leak-down test gives you lots more information to work with than just a compression test.
rustoleum82
Apr 22, 2015 07:34 PM
Meanstreak97
Aug 1, 2014 09:11 PM
4wheel_mule
Jun 24, 2010 12:54 AM
rabbet
Mar 7, 2005 11:17 AM
bebad96
17
May 3, 2004 01:59 AM
