Auto to manual flexplate
May 28, 2015 | 05:53 PM
Im swapping a m5od into my 94 ranger 4.0 2wd the only part i dont have is the flexplate between the engine to trans do i need it from the manual truck?
May 28, 2015 | 08:59 PM
A flywheel a clutch disk and a clutch pressure plate. And a clutch master cylinder.and the pedals from a standard shift ranger.
May 28, 2015 | 09:16 PM
I have all that. So i dont need a flexplate/dust sheild from donor?
May 28, 2015 | 09:24 PM
You need the metal plate that goes between the flywheel and engine block. The flywheel has the starter ring gear on it.
May 28, 2015 | 09:29 PM
The flywheel replaces the flexplate. You can't physically bolt both a flexplate and flywheel to the end of the crankshaft.
May 29, 2015 | 06:06 AM
That metal plate is what i need and meant thanks
May 29, 2015 | 06:52 PM
Metal plate (engine block plate) from a manual, not the auto.
Dave
May 30, 2015 | 07:53 PM
That sucks anyway to make the auto plate work?
pvfd1220
1983 - 2012 Ranger & B-Series
Jun 19, 2018 03:42 PM
Joel Cassell
WTB - Parts & other
Aug 23, 2016 03:35 PM
73 ford guy
May 20, 2014 06:43 PM
67F250RET
13
Sep 17, 2012 07:25 PM
Dogsnatcher420
Jul 22, 2011 08:45 PM
