Rear end clunk
Old May 16, 2015 | 05:45 PM
jctrucking's Avatar
jctrucking
Rear end clunk
I have a noise in my rear end, if I grab the bed of the truck, and rock the body back and forth, I hear a clunk, almost sounds like a wheel is loose, but checked them, all good, also checked the U-joints, and pulled the driveshaft to grease the spindle. Thinking it could be in the third member, maybe the Differential pinion shaft, or the lock bolt......any suggestions, or help would be appreciated.
Old May 16, 2015 | 06:09 PM
g_k50's Avatar
g_k50
Check the wheel bearings.
Old May 16, 2015 | 06:17 PM
ScallyWaggler's Avatar
ScallyWaggler
Also check axle shaft end play in differential. My 1999 F-150 with 9.75" rear did same but never caused an issue for me.
Old May 20, 2015 | 10:50 AM
jctrucking's Avatar
jctrucking
Not making a growling noise, so ruled out Bearings, have it narrowed down tp the differential Pinion shaft has worn down.
keyul
1997 - 2003 F150
May 31, 2016 09:33 PM
mudslingur
Jul 21, 2007 02:48 PM
nojeffgordon
1978 - 1996 Big Bronco
Dec 21, 2006 09:09 AM
98_XLT
1997 - 2003 F150
Jan 2, 2006 08:26 PM
waltmoe
May 23, 2003 10:29 AM
