Sponsored by: Auxito
rear end noise
Old Jan 2, 2006 | 07:10 PM
98_XLT's Avatar
98_XLT
rear end noise
Hello all, I'm having a problem with a noise in my rear end. It is a humming sound, like a bad bearing. I've replaced both wheel bearings,seals and fluid and still have the same noise. It's at low speeds cruising around 45mph and gets louder and more consistant at 55mph and up. I can also feel the vibration on the floor at these speeds. Someone was telling me that it could be my pinion bearing. Any thoughts.
Old Jan 2, 2006 | 08:13 PM
steve(ill)'s Avatar
steve(ill)
could be the drive shaft universal joints also. take drive shaft loose from rear end. jack up tire a couple inches and turn pinion to test it, then wiggle the universal on the drive shaft to test it.
Old Jan 2, 2006 | 08:26 PM
98_XLT's Avatar
98_XLT
Ok I'll check it out, I didn't think that the u-joints could make that much noise.One of the techs that works with me is going to check it out this week.
greentruck72
20
Aug 5, 2016 07:30 AM
96f15013ddie
Oct 10, 2013 10:04 AM
FoundOffRoadDominate
Jan 24, 2012 08:35 PM
jamespud
Oct 30, 2006 10:08 PM
fischone
2004 - 2008 F150
Jun 24, 2005 09:28 PM
