Rear end clunk
Old 05-16-2015, 05:45 PM
jctrucking's Avatar
jctrucking
jctrucking is offline
Rear end clunk
I have a noise in my rear end, if I grab the bed of the truck, and rock the body back and forth, I hear a clunk, almost sounds like a wheel is loose, but checked them, all good, also checked the U-joints, and pulled the driveshaft to grease the spindle. Thinking it could be in the third member, maybe the Differential pinion shaft, or the lock bolt......any suggestions, or help would be appreciated.
Old 05-16-2015, 06:09 PM
g_k50's Avatar
g_k50
g_k50 is offline
Check the wheel bearings.
Old 05-16-2015, 06:17 PM
ScallyWaggler's Avatar
ScallyWaggler
ScallyWaggler is offline
Also check axle shaft end play in differential. My 1999 F-150 with 9.75" rear did same but never caused an issue for me.
Old 05-20-2015, 10:50 AM
jctrucking's Avatar
jctrucking
Not making a growling noise, so ruled out Bearings, have it narrowed down tp the differential Pinion shaft has worn down.
keyul
1997 - 2003 F150
05-31-2016 09:33 PM
mudslingur
07-21-2007 02:48 PM
nojeffgordon
1978 - 1996 Big Bronco
12-21-2006 09:09 AM
98_XLT
1997 - 2003 F150
01-02-2006 08:26 PM
waltmoe
05-23-2003 10:29 AM
Quick Reply: Rear end clunk
