Instrument cluster plate/gauge/bulb holder
Old Mar 16, 2015 | 05:17 AM
77F350RangerSCS's Avatar
77F350RangerSCS
I finally replaced my crumbling white plastic cluster plate with an aftermarket one. Cleaned and refreshed the gauges, repainted the needles, all new bulbs, new lens and bezel.
All excited to have all the lights working and nice and bright. Only to find that the replacement plate thou also white plastic is very translucent and allows the turn signal lamp light to shine thru the plastic and illuminate the seat belt warning or brake warning while blinking. I did make sure the other warning bulbs are not lighting like shorted circuit plate.
Plate was bought from reputable well know truck parts supplier and I would guess is the same one sold by any of them.
Looking like I will have to take it all apart and paint the plate black? Anyone that has bought one must have same problem... anyone?
Old Mar 16, 2015 | 06:01 AM
march's Avatar
march
I have some bleed over as well. I assumed it was due to the LEDs I put in it, but also used a new housing from a reputable (DC) dealer. I'll be interested in what you learn.
Old Mar 16, 2015 | 09:45 AM
77F350RangerSCS
I will take it back apart and probably paint it white. Black may hide the bleed thru better but maybe dim the brightness too much.
You would think the manufacturer or suppliers would verify the product works as intended before selling them.
Old Mar 16, 2015 | 10:06 AM
ZarK-eh's Avatar
ZarK-eh
Was going to suggest painting it white, but you got that covered
Old Mar 16, 2015 | 02:21 PM
HoustonDave's Avatar
HoustonDave
Maybe paint the relevant areas silver and see if it helps your lights a bit too?
Old Mar 25, 2015 | 05:09 AM
77F350RangerSCS
Ended up just painting the inside of the "tube" areas of the turn signal and warning lamps black. Did the job of eliminating the bleed thru and really did not hurt the brightness of the indicators enough to worry about.
Old Mar 25, 2015 | 05:20 AM
vtpkrat2's Avatar
vtpkrat2
Wowser! A follow up/closer on a problem! Thanks 350Ranger! Glad you got it going. Gary
stowbilly96
Sep 16, 2017 01:49 AM
Rusty_S
59
Jun 28, 2015 05:47 PM
Spool&Go
15
Oct 10, 2012 04:42 AM
DirtStripHero
1997 - 2003 F150
Sep 12, 2009 02:11 PM
Dustin_86
Electrical Systems/Wiring
Oct 21, 2004 09:10 PM
