Offroad & 4x4
4x4 not engaging all of the time
Old Feb 24, 2015 | 07:22 AM
pdanielc's Avatar
pdanielc
Hi'
I have a 2000 f250 SD 4x4 auto trans. with manual lock in lock out hubs I live in Ky where we have had some bad weather I have been going from 2 wheel to 4 wheel drive quite a bit but in the past couple of days I noticed 4x4 is not engaging all of the time but when it does the 4x4 dash indicator lights up but when it doesn't engage the 4x4 light indicator isn't on any info is greatly welcome and thanks a lot
Old Feb 24, 2015 | 02:37 PM
tjc transport's Avatar
tjc transport
i ain't rite
are you pulling the shifter all the way back into gear? you can think it is in gear but not be fully engaged.
Old Feb 27, 2015 | 06:13 AM
pdanielc's Avatar
pdanielc
Hi, thanks for your reply it hasn't a shifter it has the dial switch on the dash
Old Feb 27, 2015 | 07:12 AM
tjc transport
i ain't rite
ouch.
there is all kinds of things that can go wrong with that silly setup.
bad electric shift motor on the transfer case, bad switch in the dash, to failing electronic components in the computer system.
sorry i can't be of more help, i run far away from ESOF trucks as fast as i can.
Old Mar 12, 2015 | 12:25 AM
1989seventhree's Avatar
1989seventhree
Hoping I can be of some help. The easiest thing to try with those electronic shift styles when they're acting up is just playing around with it for a while. My dads buddy has a truck with electronic transfer case shift and it wasn't working all the time. Before he took it to a shop my dad told him to try playing around with it (engage disengage, engage disengage etc.). After a while he said it worked and its been shifting fine. He didn't use his super frequently just once in a while, I guess these electric shift ones can get a little funny if they sit a while. Just something easy to try, hope it helps!
Old Mar 15, 2015 | 04:54 AM
pdanielc's Avatar
pdanielc
thanks I will give it a try
ddiercks
Dec 11, 2013 08:54 AM
jimmystoys
6.7L Power Stroke Diesel
Feb 28, 2013 11:58 AM
rsat350
Aug 3, 2011 06:12 PM
Benny2002
24
Aug 21, 2008 05:24 PM
hush210
1997 - 2003 F150
Feb 11, 2008 04:21 AM
