4x4 controlls
Aug 1, 2011 | 08:08 PM
4x4 controlls
i just got a 09 f350 XLT 4x4, v8, auto, it has both a shift on the fly dail on the dash and a 4x4 shifter on the floor
The hubs have lock or free as options.
The owners manual reads like you should have either ESOTF or a manual shifter.
What do I have to do to use in the 4x4 mode?
Very confused!!!!!!!!!
thanks,
Rob
Aug 1, 2011 | 08:23 PM
You have a truck that someone has modified. How, we can only guess.
My best guess is that they converted it to manual shift. Crawl under the truck and follow the linkage from the shifter and see where it goes. Probably to the transfer case. If this is the case, it's manual shift and the dash switch won't do anything.
Aug 1, 2011 | 08:26 PM
Thanks for the info, i will check it out tomorrow.
Aug 2, 2011 | 10:48 AM
Because of the hubs you have, my guess is that someone replaced a broken dash panel, and the switch is just filling an empty hole.
Aug 2, 2011 | 04:52 PM
just check out the ESOTF dial, does nothing
floor shifter controlls 4x4
thanks for your input
Rob
Aug 2, 2011 | 05:07 PM
Just change out the dash bezel for one from a 2WD truck, one without the cutout for the ESOF switch and no problems. The floor shifter is better anyway.
Aug 3, 2011 | 03:53 AM
Good idea
Do u know how to remove the old one
Aug 3, 2011 | 05:50 PM
a hammer usually does the trick.
id imagine it just snaps in and out..
but then again??????????????????????
Aug 3, 2011 | 06:12 PM
Quote:
Originally Posted by
rsat350
Good idea
I don't on the newer trucks. I could help you if it was a 99-04.
Rtr2017!
Apr 9, 2018 06:32 PM
socuban
Nov 4, 2016 04:33 PM
ddiercks
Dec 11, 2013 08:54 AM
RedDragon777
Nov 27, 2007 10:26 AM
pwrstrk
Nov 7, 2004 06:59 PM
