2005 F150 wiper fluid clog
Old Feb 11, 2015 | 04:50 PM
gymbo88's Avatar
gymbo88
My 05 F150 wiper fluid nozzle is in drip mode on the drivers side, pass side works fine. Is there an easy way to unclog, without having to remove that plastic shroud that surrounds it? Thanx
Old Feb 11, 2015 | 08:25 PM
1saxman's Avatar
1saxman
Okay, I haven't done this on my truck, just previous vehicles, but you should be able to make it work. Do you have compressed air? A dust-off can might work with the straw right on the nozzle. Anyway, you open the hood and find a union in the supply hose to the nozzle. Separate the line so the water/trash you blow out has somewhere to go. Now blow air into the nozzle which cleans it and blows any objects back down the supply line and out. Another thing that makes a mess but works is a Water Pik. In fact, this probably does the best job because it literally flushes out the line. You can even put windshield washer solution in it. Just the same as with the air, put the nozzle on the orifice and back-flush the nozzle and supply line.
Old Feb 11, 2015 | 09:40 PM
1Gnome's Avatar
1Gnome
I was having this very same issue, thanks for the tips.
Scott in TX
Oct 13, 2017 10:00 PM
Bigbb27
2009 - 2014 F150
Jan 5, 2014 11:03 PM
1994 F150
Sep 3, 2012 04:33 PM
GWTF150
1997 - 2003 F150
Aug 5, 2008 07:57 PM
bigwillie23
Feb 3, 2007 09:00 AM
