Halo Install
Old Feb 9, 2015 | 09:56 PM
kylegabbert's Avatar
kylegabbert
Halo Install
Does anyone know what size halos to get for 2004 f150 headlights? I need the size for the main light bowl and for the turn signal bowl. I don't want to pay almost 200 for the Oracle kit. Any help would be appreciated.
Old Feb 11, 2015 | 12:58 AM
1Gnome's Avatar
1Gnome
Are you wanting to fit the halos within the lighting case(custom hacking) or replacement units with halos already included?
Old Feb 11, 2015 | 07:24 AM
kylegabbert
Im planning on retrofitting some projectors into my headlights, and want to fit the halos inside of the case. The biggest I've seen are only 120 mm halos. Thanks for the reply
Old Feb 11, 2015 | 08:54 PM
1Gnome's Avatar
1Gnome
Smile
I gotcha now. I too researched this issue with a different application in mind.
These two links should help.
White backing
https://www.superbrightleds.com/more...ent-lights/49/
Black backing
https://www.superbrightleds.com/more...-circuit/1117/
The white circuit has more sizes than the black circuit ones. Each have many color options.
Note: the install pictures with the links, have some valuable tips of how to get housing apart, as you might have to measure to the right sizes.
Hope this helps your project!
Old Feb 11, 2015 | 11:11 PM
kylegabbert
White backing
Black backing
Thanks! I think im going to just get strips of side emmiting leds and use those, the highest halo they sell is the 120 mm which is still to small! But I like the idea of using the leds and using them instead of a halo
Wing8
Dec 1, 2014 07:12 AM
asterof
1997 - 2003 F150
Nov 15, 2014 12:43 PM
popuppaul23
1997 - 2003 F150
Dec 11, 2007 09:28 AM
griffbw
2004 - 2008 F150
13
Feb 14, 2005 10:38 PM
vuduranger26
1983 - 2012 Ranger & B-Series
Nov 30, 2003 03:53 AM
