Wiper Fluid Aim
Old Jan 26, 2007 | 07:48 AM
bigwillie23's Avatar
bigwillie23
Wiper Fluid Aim
Does anyone know how to adjust, if at all possible, the aim of the windshield wiper fluid? Mine aims too high, and it's just a waste because it doesn't get on the main part of the windshield to do any good.
Thanks!
Old Jan 26, 2007 | 08:28 AM
Darth Baiter's Avatar
Darth Baiter
Try inserting something in the discharge hole in order to rotate the nozzle. Most wiper fluid discharges can be adjusted this way. Careful what you use does not get stuck or cause damage.
Old Jan 27, 2007 | 07:11 AM
AJ-69's Avatar
AJ-69
Try using a safety pin to adjust
Old Feb 3, 2007 | 09:00 AM
madsonp's Avatar
madsonp
A lot of times this can be caused by dirt, scale etc. partially blocking the spray tip. Disconnecting the tube that feeds the fluid to the nozzle in question and blowing backwards through it with compressed air can clean this out and return the tip to it's normal spray pattern
cleaningbug94
13
Oct 18, 2010 03:13 AM
StanfordThompson
Nov 18, 2009 05:27 PM
ErrorS
Aftermarket Products
Oct 17, 2007 02:17 AM
packlet
Sep 9, 2004 11:06 PM
abendx
Apr 16, 2002 12:36 AM
