Outside Temperature Display
Old Feb 2, 2015 | 08:29 AM
roadkingfl's Avatar
roadkingfl
I cannot believe outside temp is not available on 2015's...I don't see it on any screen or in the manual.
Anyone know?
Old Feb 2, 2015 | 08:35 AM
System's Avatar
System
Prolocutor
I think someone just posted on this that it's available in the MFD in the center of the dash now instead of over in the climate control area.
crb478's Avatar
crb478
It displays on the center screen in my Lariat at the top with the radio info.
Old Feb 2, 2015 | 08:36 AM
System's Avatar
System
Prolocutor
Link to post.
https://www.ford-trucks.com/forums/1...l#post15046074
Old Feb 2, 2015 | 08:46 AM
roadkingfl's Avatar
roadkingfl
My 11 used to display in the center info console (I think?) this one doesn't...There must be a parameter I need to select or something along those lines.
Old Feb 2, 2015 | 09:29 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Center Console......."Home" screen.......Very top.
On EDIT: Other screens too......
Very Top of screen............
Old Feb 2, 2015 | 09:51 AM
roadkingfl's Avatar
roadkingfl
Not on mine Mr.Roy...
Old Feb 2, 2015 | 09:57 AM
roadkingfl's Avatar
roadkingfl
OK just found it...It is selectable on the clock set up screen...Just turned it on.
Old Feb 2, 2015 | 10:15 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Good Find............I don't remember turning it ON.......Maybe the dealership did it for me......
I did find in the menus where you can create new codes for the door keypad. That was nice.
Anyone find a way to turn OFF the display ???
My 2011 had a button....lower right side, I believe.
At night on dark roads, I like to have as little light in the Cab as possible.
Old Feb 2, 2015 | 10:20 AM
EO2SeaBee's Avatar
EO2SeaBee
Roy, I don't know that you can necessarily turn it off, but in the settings, you can go manual or auto and set how bright to have the display.
Old Feb 2, 2015 | 10:25 AM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Thanks Doug......I did find that. I hope to find out how to turn the display OFF. The radio still plays (as an example ).......Just do light.
Old Feb 2, 2015 | 11:04 AM
Specularius's Avatar
Specularius
settings, display, mode, off.
I turn mine off all the time when driving at night. Automatically resets to on when the key is turned off or you touch the screen.
Old Feb 2, 2015 | 12:04 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Thank You......
It is so great to have the help of others.......
Old Feb 2, 2015 | 06:50 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
I looked today........yep, right in front of me......
I also discovered......if I want the display back on, without restarting the truck, I just touched the screen.........
gustrider4
Apr 13, 2019 01:20 PM
SS70ElCaminoOwner
Mar 6, 2016 12:52 PM
90pioneer
6.7L Power Stroke Diesel
Jun 23, 2015 07:56 AM
KC8QVO
May 30, 2011 09:05 PM
tyger25
Aug 14, 2003 12:53 PM
