Fuel tank problem or not?
Old Feb 2, 2015 | 05:29 PM
sgrol's Avatar
sgrol
When I fuel up and open the cap on the filler neck I always hear a hiss. Never could figure if it was pressure or vacuum. Today, after changing oil, I opened my fuel filter bleeder to check for water and it just started slurping and gurgling with no diesel coming out. I lowered the truck, removed the fuel tank filler cap and heard the hiss. Raised back up and opened the filter bleeder and diesel came out. I now know the hiss is a vacuum. Is this normal? If this tank is vented I have a problem somewhere.
Old Feb 2, 2015 | 05:31 PM
sdetweil's Avatar
sdetweil
there is a plastic L vent on the end of a tube, up by the filler hose as I recall.
Old Feb 2, 2015 | 05:46 PM
sgrol's Avatar
sgrol
I saw that in a pic while searching for this problem. I will have to check that and see if it is plugged. I've always thought the hiss, be it pressure or vacuum, was normal.
Old Feb 2, 2015 | 05:48 PM
sdetweil's Avatar
sdetweil
I don't get a hiss when I open the gas cap
Old Feb 2, 2015 | 05:50 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Mine does it all the time if I take the fuel cap off right after shutting it down unless I let it sit and idle for a while before opening it up or let it sit after shutting it down.
So far there hasn't been any issues from it.
Old Feb 2, 2015 | 06:15 PM
sgrol's Avatar
sgrol
Mine seems to depend on tank level. I was 44 miles from empty today and it had quite a vacuum. It had sat about three hours before I cracked open the fuel drain valve and then the filler cap later.
Old Feb 2, 2015 | 07:04 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
I almost never take the fuel cap off unless the tank is empty and I'm fueling it up, so I couldn't tell you much about when it has a lot of fuel in it.
jtmalott
Jul 6, 2017 02:35 PM
glovemeister
Sep 10, 2013 06:36 AM
CanadianBlake
Bio-diesel, Propane & Alternative Diesel Engine Fuels
19
Sep 21, 2012 10:02 PM
27ModelT
Jul 9, 2011 01:34 PM
SERGE13
Jun 7, 2010 10:44 AM
