Advice for those prepping and painting a bonus built hood
Old Jan 7, 2015 | 05:11 PM
49willard's Avatar
49willard
I am in the process of prepping/block sanding the hood on my F-1. I had stripped it to bare metal, did a bit of filling on the top and shot 1st prime. I decided that I should install the radiator dam with new rubber that is installed in the forward part of the hood since it would have the potential to push the hood up where the rubber on top of the air dam contacts the hood.
The short answer is that it will push the hood up just a little such that I recommend installing it for the final blocking of the hood. Waves in the hood will haunt you forever!
Old Jan 8, 2015 | 02:16 AM
52 Merc's Avatar
52 Merc
That is good advice, Bill. It's no different than using a torque plate when boring or honing cylinder walls in your engine. Having the bracing in place makes all the difference in the world for working with the correct shape. Sitting in the drivers seat, flaws in the hood will catch your eye every time you drive the truck.
Old Jan 8, 2015 | 08:29 AM
ChuckRob's Avatar
ChuckRob
Bill I have one of those waves in the hood that your talking about. Most people can't see it but I can. It didn't show up until I put on color. I resanded, glazed, primed, guide coated, reshot the hood and clear and in the right light there it is again.
Sometimes it is just not fun being the guy that did all the paint and body work because we know were all the bad spots are.
Old Jan 8, 2015 | 01:38 PM
abe's Avatar
abe
Are they the same for 48-50 and 51-52? I have one from a 52 truck. If anyone needs one let me know.
On another thread about this piece it was brought up that they are important for forcing air into the radiator and not around it.
Old Jan 8, 2015 | 02:22 PM
52 Merc's Avatar
52 Merc
The deflector plate that fits in the hood is the same for 48-52. But they are different for 6 or 8 cylinder, as the radiator position is different and it requires a different sized deflector to match.
Old Jan 8, 2015 | 02:25 PM
abe's Avatar
abe
Oh, that is good to know! Mine is from a 6 cylinder. Thanks.
Old Jan 8, 2015 | 05:57 PM
49willard's Avatar
49willard
Chuck,
I ended up rebending the tabs at the outer ends of the air dam such that I eased the pressure where the rubber gasket pushes up on the hood. It helped considerably.
I agree with your last sentence!
Old Jan 8, 2015 | 07:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's probably too late if you have paint on the hood, but another thing to check is the fit to the cowl. They seem to get "flattened" on the underhood brace that connects the hinge points on the hood. That makes it hard to get the hood to sit down properly.
Old Jan 9, 2015 | 06:12 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
That's a great tip on the Bonus Built hoods.
I'm not running a deflector in my truck. I have a custom radiator and shrouding so I don't need the hood deflector. But, I'm wondering if it might be necessary to add something in there to create a little stiffness in the hood. Hmm, just something else to fabricate.
Bobby
bjmayberry2
Mar 3, 2018 01:46 PM
bigbubba87
24
Jul 4, 2013 02:46 PM
snakechaser
Dec 18, 2005 07:26 PM
fish-albuq
Sep 5, 2004 03:06 PM
twr
Apr 14, 2001 07:50 PM
