Need electrical a/c help on 77 F150
Old Oct 12, 2014 | 08:08 PM
Haydendh's Avatar
Haydendh
I decided to replace the blower motor on my truck because nothing happens when I turn on the fan. After I took off the vent cover that exposes the evaporater and condenser I noticed the blower motor plug was melted some. So I decided to stop right there and see if I had power to the plug and nothing. Next I went to the resistor. There was no power to either one of the plugs on the resistor. Next I went to the relay , the relay has power on one of the prongs. So I thought maybe it was the relay, replaced it with a part number I found on another thread from oreillys and still no power at the resistor. Can someone tell me what the chain of power is on this whole process. Which plug is suppose to have power on the resistor and where does the relay come in to play? Thank you
Old Oct 12, 2014 | 09:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Go here:
https://www.ford-trucks.com/forums/1...then-some.html
And here:
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
If you go to Fordification, you can use the '76 wiring schematics. The A/C wiring is the same as your '77.
Old Oct 12, 2014 | 09:19 PM
Haydendh's Avatar
Haydendh
I looked at all those before but they don't tell what feeds what. I know how it all hooks up just not sure what is suppose to be hot and so forth. Thank you though
Old Oct 12, 2014 | 09:33 PM
Haydendh's Avatar
Haydendh
Let me rephrase that, I think that one schematic may show what feeds what but I can't understand it lol.
Old Oct 12, 2014 | 09:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Okay, go to page 4 of the '76 wiring diagram, upper left you'll see the A/C circuits. Look at the "safety relay", that's what Ford calls it. Everyone else calls it the blower relay.
The wire that you showed was hot should be the orange one. The one that controls whether this relay turns on or not is the yellow w/ red trace wire, circuit #753. With the A/C on check whether you have voltage at the relay plug. If you don't show any voltage, go to the A/C mode switch (on the A/C control panel) and check for voltage at the orange wire, circuit #181. If you show voltage there you need to replace the switch, this is part of the vacuum control switch and isn't available separately.
This is what the switch looks like.
Old Oct 12, 2014 | 10:32 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here is some more a/c help.
1979 F100 Air Conditioning
NORTH COUNTRY SPECIALTIES ®
Old Oct 13, 2014 | 12:20 AM
Haydendh's Avatar
Haydendh
Would you have the part number I can't make out the one on the box. Thank you
Old Oct 13, 2014 | 01:16 PM
Haydendh's Avatar
Haydendh
Ok I have power at the yellow wire on the relay, but that's it. The power goes off when I turn the ac off. You can hear the relay click when I turn it on and off so I think it's good, plus it's brand new.
Old Oct 13, 2014 | 01:55 PM
Haydendh's Avatar
Haydendh
Update
I checked the vaccum control switch and it seems to be working properly. Does anyone know what all wires should hAve power going in to the relay?
Old Oct 13, 2014 | 06:02 PM
Haydendh's Avatar
Haydendh
Boom !! Finally figured it out the orange wire ran to the starter relay ( which the previous owner just replaced) and he had it on he negative side. So after buying a new blower motor, relay, and heater core it was just a crossed wire lol. Thanks everyone for the help.
Old Oct 13, 2014 | 06:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Glad you found it .
Quite often the worst thing that can happen to one of our trucks is a "previous owner".
d.west5353
Jan 11, 2016 07:02 PM
Carny
Feb 12, 2011 12:01 AM
TheRed
Electrical Systems/Wiring
Sep 22, 2009 05:31 PM
cvdenson
Sep 16, 2006 04:18 PM
76BIG/ORANGE
Feb 23, 2006 06:22 PM
